Archive-8
Just sent you a pmI had tried version 1.0.2.118 when it came out, but still couldn't get it to change the LO in KA Inverto option.
I'll try your version if I may Chris, could you send me a PM too please?
That's good going, what size dish is that on please?Great, thanks for this version of Crazyscan , it works well with the BBC and 6983.
Just made a test between SL3 and XMW DRO and the result is not so bad for the SL3 !
PS: same antenna and weather conditions (not good)
in H:
SL3+BBC:
XMW DRO
In V:
SL3+BBC:
XMW DRO:
Yes, Crazyscan v88. Won't work with the TBS 6983 though, only cards like the TBS 6925/5925 and Skystar Xpress HD.
Crazyscan2 is for DVB-T/C cards.Hi,
I have just noticed there is a CrazyScan2 version as well as a CrazyScan version. Would anyone please be able to tell me what the differences are between these versions? Also, are both these OK for Ka Band?
Thx
There's a later version of Crazyscan which we are now using for the SL3 LNB. Drop Chris1979 a PM for his link to the version, I'm sure he will kindly oblige.Llew,
Would you please have a link to the v88. version of CrazyScan?
Also, do you know if I need any special version of other files such as streamreader?
Thx
