Summer house project
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Hi all, i managed to nearly get the front finished, i am getting an feeling of the size of it now, it looked small until the front went up, BTW outside measurements are 15ft x 9 + the brick built shed, hopefully nothing will slow me down tomorrow apart from the heat :eek:, end of work pictures today :) just the top section to fit in and finish making the weather board for the window:).
View attachment 76379 View attachment 76380 View attachment 76381 View attachment 76382
Hi Martin.....¿assuming the dish mounted on the wall is facing the Astra 2 range, is your aspect from the garden basically facing true south.....with a clear 45W to 62ºE LOS?
No other way to put it but good luck today with your erection...........summer house wise that is! :D:D
Archived-1
Persona non grata
uk
Where the dish is atm J, I can get 62E to 63W if I solved the dish flop problem, only data so ive been told at 63W, I am hoping to get further E from the positioning of the 1.8, that's the main reason why its going up high:).
This thread will show you what I am trying to do J :),
Thanks for the good luck :), if I do have any erection problems I am sure I will sort them out :).
https://www.satellites.co.uk/forums/threads/how-accurate-is-dishpointer.163433/
:D
sonnetpete
wordpress.com
Normandy, France
....additionally, ensure you have lead in your pencil.........
Archived-1
Persona non grata
uk
Lunch time update, weatherboard made and installed, this will be the same colour as the outside finish, the red is just to preserve the wood, I am unsure what to clad it with probably loglap, top bit fitted and all protected, the window can go in now when I can get a lift with it,
I will move to the long run after a cuppa :).
Terryl
Custom built PC
Nice work so far, but why no window header?
I would have used at least a 4x10 for the top of the window, this takes all the roof load down to the jack studs holding it up, and puts a zero load on the window frame.
I guess you all do things different then here state side.
Archived-1
Persona non grata
uk
Thanks Terry,
No need for one on this window, the roof will have a over hang and the roof load will be brought back so its not above the window ;), ive been in the building trade for over 20yrs so I have an idea what I am doing :) but thanks for the way you would do it:)
Archived-1
Persona non grata
uk
Hi I am at this stage now, I had to go and do a job so I only had a few hours after lunch.
DSCN8103.JPG DSCN8104.JPG DSCN8106.JPG DSCN8108.JPG DSCN8109.JPG DSCN8110.JPG
Archived-1
Persona non grata
uk
Looking good there! How long do you reckon it will take you to complete?
Thanks Chris, if its anything like my other projects it will be this time 2017 :-lol,
I am hoping to have it water tight Tuesday/Wednesday of next week, theirs lots of work to do inside, but I need to get this finished, if I don't run out of money probably 2 weeks time from this weekend pal.
Archived-1
Persona non grata
uk
Thanks pal, two more projects outside to this project but at a later date pal:-doh:D, the main reason for building the SH my wife is terrified of butterfly's:-doh but a good excuse for a man cave :) all my setup will be installed inside it :)
sonnetpete
wordpress.com
Normandy, France
.....and she has no qualms about the green millipede you've had painted on your dish??
Archived-1
Persona non grata
uk
No Pete, she likes millipedes, it was her idea :),
One thing that had to be spot on was the distance from the stud wall by the side where the 1.8 will be, and the height of the sleeper for the gutter to fit and work, it looks like I have it spot on :).
Journey
drx 890
Martin, hope you don't mind me asking, are any of the surrounding neighbors going to be able to see the 1.8m from their houses ? Are you worried about council etc... ?
Archived-1
Persona non grata
uk
No I don't mind, yes surrounding neighbours can see it, but I have planning permission for the dish, and the summer house is permitted development, so no I am not worried :).
Journey
drx 890
Was it quite easy in your area to get the planning permisson? I am only asking as you know i have had problems in the past.
Is there a special method to obtaining the permison needed ?
Sorry to go off topic, genuinely interested for future projects, thanks in advance :)
Archived-1
Persona non grata
uk
Yes it was easy, but only two people can see it from there living room and I am one of them, if you look at a thread I posted about my bros ham mast and antenna you should not need it anyhow but I did it as a precaution , I need to dash out in a moment I will find the thread later and point you to it if you don't find it in the mean time:),
One window installed :)
Archived-1
Persona non grata
uk
Ha! Ha! Ha! move south a little, in July:-hijack
Its warm enough here Brian, my back garden is south facing with at least a 7ft fence round it, so not much of a breeze, god knows how hot it will be in July, my GH is hitting 35/40 on a nice day now :eek:. and its not that much cooler in the garden.
it was easy for me with my neighbour works in the office, it looks like you've seen this thread, but I would chase the links up for your area, like I say in the thread they had no idea about it :eek:. if not just apply but get a plan drawn up, most reasons people don't get planning permission for anything is there plan, you can pay someone online to do this for you.
https://www.satellites.co.uk/forums/threads/planning-permission-for-ham-radio-antenna.163846/
