Astra 2G: Testing at 43.5°E
First test carrier... frequency 10714 H
Other test carrier, 11616 H
Very strong signal in my area on 11613 H.
11692 V has been activated
Another one activated at 11224 H:
It cant be a coincidence that most of the tp's being lit up so far are in the the remaining Eutelsat 28A band.....
A correct observation. To that I thought myself when I saw them.
Repeating the ranges as listed on tsenki.com:
7,250–7,750 MHz
10.70–11.20 GHz, 11.20–11.29 GHz, 11.45–12.19 GHz
18.85–21.20 GHz, 21.40–22.00 GHz
Let's see if indeed the range 11.29...11.45 remains untested...
M60
Northern England
I'll start a spreadsheet at home to try and track whats being tested from reports and post periodically.
AS, is it time to open a new topic now testing has begun?
11264 H is activated now:
tempo
47.5N, 42.2E / Russia
It is surprise for me, but I have strong carriers inRussia too :)
All previous Astra tests at 43.5°e were very weak here.
Archive4
Before we all get too excited, anyone got 2E data to cross reference? ( Always the pessimist, if the spot beam is lower, " GAME OVER " !
11224 V on:
tempo
11224V in my location
The weaker signal at 12474 V:
tempo
Can't confirm. Also 12474 V doesn't match expected frequency plan.
Maybe beacon?
Perhaps,because after scanning the signal disappeared.Around this time started a new transponder at 12655 V, which is on Astra 1F,but also this transponder left.So far this transponder doesn't really exist.There are tests on Astra 1F?
