thor 7 launch 16 april 2015
4wd
Getting the picture
5 W, 9-13-19-28 E
Fantastic in all respects.
adonis1
Thor 7 IOT will be at 12°W, telemetry: 12494.5 & 12495.5 LHCP.
Sicral 2 (alternative name: Syracuse 3C) destination is 37°E.
In the speech a few minutes ago it was said, the old Sicral 1 (21.8°E) will live its extended life until 2018.
adonis1
Launch of Thor 7.
tempo
47.5N, 42.2E / Russia
Intercepted telemetry Thor 7 to about 14.5°W.... frequency 12494,50 LHCP and 12495,50 LHCP
The Thor 7 has maneuvered and changed orbit (now is around 14,5°W), no longer follows the TLE.
tempo
With last TLE the sat is stopped at 14.5°W
TLE must have been updated while you wrote Marcus_21, says 14.5°W as well now!
Predicts steady movement of 0.6° per day now, 12°W would be reached on 6 May.
tempo
Maybe tomorrow Thor 7 will arrive 12.0°W position for testing. By the last TLE it is at 12.5°W already.
tempo
By the tracking, Thor 7 has arrived 12°W.
Marcus_21, can you confirm this by telemetry signal?
No beacon/telemetry for Thor 7 where I am. Only E12WA at 12500.15 H
It confirm reached 12°W
They began testing the Thor 7... for now tested the transponder:
11727 V, 12111 V, 11766 V, 11804 H, 11843 V, 11881 V, 11919 V, 11958 V, 11996 V and 11785 H
12475 H, 12130 H, 11862 H, 11938 H, 12015 H, 12169 H, 12207 H, 12245 H, 12284 H and 12322 H
12360 H, 12399 H and 12347 H
tempo
12447V is active at the moment
All test carriers received in my location today:
12035V, 12112V, 11727V, 12447V
Today tested the transponder: 11727 V, 12034 V, 12073 V, 12111 V, 12149 V, 12188 V, 12264 V, 12341 V and 12418 V
Retired Mod
www.timo.me.uk
So far all the tests seem to be in the top end of the band where most of the Eastern European channels are. I wonder if this means that Thor 5 & 6 will be used mainly for Nordic area (Canal Digital) in the lower bands and more of the Eastern European channels moved over to Thor 7 (which has a nice eastern beam) and some of the channels that need a Europe wide beams sticking to current Thor 5/6 wide beam at the top end of the band with Thor 7.
No signals here in the East of England with a 100cm due to rain :(
I will try again tomorrow hopefully clear skies,
Nothing on SES-5 either in this weather :eek:
