INVERTO LNB
drusattv
C& KU BAND SATELLITES // 2M PRIME & 110CM OFFSET//VU+DUO2//XCRUISER 420 HD//
KA-BAND...COMMING SOON......
iran
    • NEW INVERTO LNB ( BLACK ULTRA) 02DB
Retired Mod
www.timo.me.uk
Oh, I need to try one of those and compare it to the originals!
sonnetpete
wordpress.com
Normandy, France
Interesting. There's nothing new in the 'Ultra' range on the Inverto website and the illustration of the single BU looks like it always has, all black with a white cap :
http://www.inverto.tv/products/product.php?section=1&id=57&cat=4
I'm wondering if it's a cosmetic makeover, though having had two BU's fail through what I believed was overheating, I'd be wary of buying one that has a black feedhorn cap as well...
archive10
Probably nicely made in China in the factory down the road from the factory making the ones with the white cap and lack drop-down rain cover.
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
A lot of duplicate inverto LNB's have been floating in the Indian market as well.
Normal lnb = rs.250
Inverto lnb = rs. 1900
Such a big price difference, and if u get a fake product, it really is frustrating.
Any method to find out, which ones are original and which ones fake ? :ph34r:
Tururu
Assembled with recycled parts
Recycled as the owner.
Unopened and really compare the electronics, there is only shop at trusted.
Those who have one for years and have small antennas can easily compare the levels and quality of these LNB X.
Consultare a friend antenna installer and ask at the store where you buy if they are offering cheaper units.
Looking at the photo, differences, apart from the black cover, the protective connector "F" is now white.
2 more things.
It is the twin box model used for single and lack of direction inverto.tv (TM)
Sin abrir y comparar realmente la electronica, solo queda comprar en tiendas de confianza.
Los que tenemos uno desde hace años y tenemos antenas pequeñas podremos comparar facilmente los niveles y calidad de estos LNB X.
Consultare con un amigo instalador de antenas y que pregunte en los almacenes donde compra si estan ofreciendo unidades baratas.
Mirando la foto, diferencias, aparte de la tapa negra, el protector del conector "F" ahora es blanco.
2 cosas mas.
Es la caja del modelo twin usada para el single y falta de la direccion inverto.tv (TM)
For the price it is easier to know that it is a copy.
Por el precio es mas facil de saber que es una copia.
Normal lnb = rs.250 ==> 3.51€uros
Inverto lnb = rs. 1900 ==> 26.70€uros (the original. ??)
In Spain 17 €uros 2 years ago/En España 17€uros hace 2 años (Inverto single IBU 0'2dB ).
drusattv
iran
look here::
drusattv
iran
sonnetpete
wordpress.com
Normandy, France
Brand new BU for comparison :
I bought one last month & my findings were the same :eek:
https://www.satellites.co.uk/forums/threads/astra-2g-testing-at-43-5°e.165161/page-8#post-926291
I switched dishes yesterday for my tests with the TM5502HD to the 104cm Gibertini as it is more directional than the 88cm mesh dish so the bleed over from 42 east & 45 east is now minimal @ 43.5 east.
I have a new Lnb in transit Inverto 40 mm Single HGLN Ultra 0.2 LNB & will test it against the Inverto Black Ultra 0.2 later today.
william-1, May 8, 2015
The Lnb is the same as the IBU just the packaging says HGLN but the Lnb in the box says IBU 0.2.:rolleyes: Signal Quality exactly the same :)
william-1, May 9
sonnetpete
wordpress.com
Normandy, France
Out of interest william-1 was your BU the one with the black label or the one with the red printing?
Black Label with black printing is my new HGLN exactly the same as my 2 spare & 2 in use Inverto Black Ultra o.2,
I have another spare with red printed Black this was the 1st one that I bought a couple of years ago.
archive10
@william-1: Just to be clear - do you have a Inverto Black Ultra Single with a black feed-horn cap and white drop-down rain cover?
Looking at the photos of the "alternate" BUS, the model number says IDLB-SINL42, whereas the "normal" BUS says IDLB-SINL40...
No all the other IBU's have white feed horn cap & black drop-down rain cover with normal BUS IDLB-SINL40 I guess the other one IDLB-SINL42 was made at a different time period ?
archive10
OR by another company (non-Inverto) "taking design inspiration" from the SINL40.
(in other words am illegitimate copy)
Just wonder why they wanted it clearly different from the original - why not make it a straight copy, after all you are into the realms of forgery.
(Of course it could still be a legit Inverto LNB, for a specialist order or something, hence the 42 model number, but it dos seem strange)
Tururu
IDLB-SINL40-ULTRA-OPP (original)
IDLB-SINL42-ULTRA-APP
IDLB-TWINL40-ULTRA-OPP (original)
IDLB-TWINL42-ULTRA-APP
More beautiful web of like the original things, but different.:-rofl2
Bonita web de mas cosas parecidas a las originales, pero son diferentes.
Tururu
About Inverto LNB, I found this in the distributors:
Sobre los LNB inverto, encontre esto en la zona de distribuidores:
http://www.dmm-tv.com
Inverto has this reference/Inverto tiene esta referencia: http://www.inverto.tv/contact/
Inverto Digital Labs
18, Duchscherstrooss
Wecker, L-6868
Luxembourg
Tel. +352 264 367 1
Fax. +352 264 313 68
info@inverto.tv
I did a test a few years ago using various coloured Lnb caps from Bisto & other products on my Invacom 0.3 Lnb after birds had destroyed the original lens cap by pecking out the Lnb cap to get the spiders :eek:
The best signals were obtained with Lnb covers were made from White & Clear Polypropylene & LDPE :)
The worst signals came from the darker colours such as Red Brown Blue & Black in harder plastic such as polystyrene & ABS :(
Tururu
........The best signals were obtained with Lnb covers were made from White & Clear Polypropylene & LDPE :)
M:W
Select preferred for the top color/Seleccionar color preferido para la tapa.
Seriously, by material, the signal is attenuated/Ahora en serio, segun material, la señal es mas atenuada.
As indicated William-1, It is good to perform various tests/Es bueno realizar varias pruebas.
Make no oversight by the initials of the company DMM.
Que nadie se despiste con las siglas de la empresa DMM.
To rely on the guarantee of their products.
Para fiarse de la garantia de sus productos.
PD:
sonnetpete
wordpress.com
Normandy, France
Was there a marked performance difference between say, chicken or beef?
