Astra 2G: Testing at 43.5°E
It has entered the Hohmann transfer orbit...
Thank you for that @Pietclock , reading up on that would appear to turn my earlier statement on its head- she is slowing down therefore the orbit altitude is reducing.
seems it will be ready for the switch on 19 June... to spot or not to spot...
astra 2g 29e
Time 10:00 (UTC)
Normally I start at 10714H.- CL4 / 10729H E4, today I see that are not always where it was necessary to move the length -0'3º to position the antenna to 100%, it seems they are modifying other satellites for the arrival or leaving a little more site not pass braking at the last moment and a hint will be satellites.
This change alters my references are jumping + 12 east where the satellite is about.
Located the satellite, this is what I see.
Off the tp's 10700H-10770Mhz.H.
10980H beacons and are only intermittently.
In Horizontal Alta, the tp's remain active, 12480H analyzer does not identify, are data or DVB-S2.
Hora 10:00 (UTC)
Normalmente arranco en 10714H CL4/10729H E4, hoy veo que no estan donde siempre, fue necesaria mover la longitud -0'3º para posicionar la antena al 100%, parece que estan modificando el resto de satelites para la llegada o dejando un poco mas de sitio no se pase de frenada en el ultimo momento y se den un toque los satelites.
Este cambio altera mis referencias, son 12 saltos + al este donde esta el satelite aproximadamente.
Localizado el satelite, esto es lo que veo.
Apagados los tp's 10700H-10770Mhz.H.
Solo quedan balizas y 10980H intermitente.
En Horizontal Alta, los tp's continuan activos, 12480H el analizador no lo identifica, son datos o DVB-S2.
PD:Buena pesca/Good fishing.
The epoch is still 9.6.15. We don't know where the satellite _really_ is right now. Until Astra publish their own TLE data
Here I cluelessness, you pull the photo and forget expand, remain active, then put pictures of this morning 8:40 (UTC).
Aqui me despiste, le tire la foto y olvide ampliar, continuan activos, luego pongo fotos de esta mañana 8:40 (UTC).
Like this/Similar a esta:
Then I upload photos/Luego subo fotos.
Beacon Astra2G/Baliza del Astra2G.- 11198.7Mhz.
Beacon/Baliza de 28'0ºE.- 11196.1Mhz.
Indica reference using beacons and 2 channels.
Usando de referencia las balizas indicas y los 2 canales.
Astra 2E +/- 28'15ºE
Astra 2G is 12 jumps further east.
Astra 2G esta a 12 saltos mas al este.
It seems that this "parked" waiting, this at the same point +/- on Sunday.
Parece que esta "aparcado" esperando, esta en el mismo punto +/- que el domingo.
12490h i got becon
That mark is the old satellites, moving the antenna direction Astra2G I lose.
Beacon Astra2G:
11198.7Mhz H
12461.3Mhz V
Esa baliza es de los viejos satelites, al mover la antena direccion Astra2G lo pierdo.
Baliza del Astra2G:
11198.7Mhz H
12461.3Mhz V
new becons of me
11100h
Can we have a new thread now 2G is at 28E?
Has the eagle officially landed?
Given that its actual position lags behind the predicted position, probably not. But it's pretty close now.
I'll eave this open until we get the first confirmed report and then close the thread down.
Good hunting everyone!
How much is a jump ? Could it be that 2G goes to 28.5 to the position of the Eutelsat ?
Could you count the jumps between ie 28.2 and 19.2 ?
