Bond (strapped to laser-cutting table): "What, Blofeld? Do you expect me to talk??"You want me to drive to UK?!!! I can hardly cross the street there- cars are coming from the side I never expect them!![]()
As I remember the hole was 120-130cm deep, about 25-30cm wide and consumed lots of concrete and stones.
Today I decided to make this pole more universal, so upper part was taken down and will be replaced by new heavy metal (weight more than 20 kg) 8mm wall thickness piece of pipe. Will weld it to original plate to fit 4 threaded pins. Will also weld 6 20mm bolts in 2 levels. So, at the end will be able to fix any pipe inside the big one and make it dead plumb. Unfortunately not all the materials are INOX here, will be painted.
Blasphemy!!!Unfortunately not all the materials are INOX here
Ah, you're back in Latvia for a change... how's the Playground #1 doing?Some time ago I installed pole for antenna, I even had antenna on it. View attachment 80087 As I remember the hole was 120-130cm deep, about 25-30cm wide and consumed lots of concrete and stones. View attachment 80088 Today I decided to make this pole more universal, so upper part was taken down and will be replaced by new heavy metal (weight more than 20 kg) 8mm wall thickness piece of pipe. Will weld it to original plate to fit 4 threaded pins. Will also weld 6 20mm bolts in 2 levels. So, at the end will be able to fix any pipe inside the big one and make it dead plumb. Unfortunately not all the materials are INOX here, will be painted. View attachment 80089 View attachment 80090 View attachment 80091
, rest I drilled out by usual drill bits
. So, at the end I have 6 x 18mm holes and 3 x 22mm holes.
Therefore decided to acquire 9 x 16mm INOX nuts and 9 x 16x 60mm galvanized bolts, Yes, bolts will be galvanized in purpose (do not think I am going crazy
