- Some SAT-related hardware.
- N-E from Riga
Martin! Thanks for advices. I will repost same picture I posted before. what do you think is there circled red?
Yes, correct, it is device which regulates speed of the drill, it changes voltage from 0 to 220V. And drill is powerful enough to drill on small rpms. Of course I made 9 x 6mm holes and then crown drill (green) is centered to these holes. Crown drill does not need many holes to be drilled.
But, OK, drilling is over, I will go to the next steps now.
Agree with you, I need more practice. If I do it once per year or little it often, I also make some mistakes.
, keep at it
