- Some SAT-related hardware.
- N-E from Riga
Brought home 2 pipes today
- 740mm x 140mm and wall thickness 8mm
- 1950mm x 89mm and 4mm walls. Have cut this pipe into 2 pieces 500mm and 1450mm.
89mm that what I need to fix NSC 1,8m antenna's polar-mount
. And vertical pipe from Prodelin dish has about 100mm diameter
. So, I am going to make adapter from 100mm to 89mm by welding together (do not know yet how) 140mm pipe and 89mm pipe, like this
Not easy to explain, will better show some pictures when everything up and running.
: - 740mm x 140mm and wall thickness 8mm
. Not easy to explain, will better show some pictures when everything up and running.
