Eutelsat 7 West A at 7.3°W
Archived-1
Persona non grata
uk
Hi anyone getting this TP from now and this day forward not what you've had in the past please.
capture-jpg.81563
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Archived-1
Persona non grata
uk
I am talking now Rimants please not the past.
My first post is now edited.
Got the test card for TDA here on 11661V, SR27500 from 7.3W, picture locked, Monday 27th July 2015
Just scanned again for 11661V, SR27500 on another receiver and got:
Test 1
Test 2
TV A3 (Algerie 3)
TV Tamazight (Algerie 4)
TV Coran (Algerie 5)
Test 6
Test 7
Test 8
Test 9
Test 10
Test 11
All with pictures or test cards, all bimming in loud and clear here, Monday 27th July 2015, 23:00 UK local time.
That Flysat site has better listings than that LyngSat site for this transponder.
Archived-1
Persona non grata
uk
Thank you D, what dish is this with please, I am presuming its not on the 90cm in your sig ?
Martin,
Its with a Precision 1.5m prime focus dish.
Just done a quick test with 3 different receivers for a few transponders, the results are in the picture attached below.
The TM-5402 (M3) is reporting stronger signal levels that the Dr HD F15.
Nothing changed for me from my last report. Easily lockable and scannable but picture breaking up a lot.
CJ,
No picture breakup here using either F15 or TM-5402 (M3), however, I am a hundred or so miles further east, probably helping to prevent picture break up.
I don't know if my F15 is going deaf but I am not getting anywhere near a lock on this frequency on it...
Archived-1
Persona non grata
uk
If you can easily access the dish put the lnb as far back as it will go and see what happens
Them F15's aint what they cracked up to be, outdated and with false reputation if you ask me. I got a TM-5402 (M3) here getting a better signal than one of them F15's using same dish, same LNB cable. Stick that new TM-5402 (M3) you got on it, it will probably lock it.
The F15 did eventually lock it. The 5402 M3 is no better or worse than the Uno, constantly breaking up on this TP. We are splitting hairs with these receivers.
Tururu
Assembled with recycled parts
Recycled as the owner.
I do not see change now and in the past, put what you have now and some photos from the past.
No veo cambios ahora y en el pasado, pongo lo que tiene ahora y unas fotos del pasado.
Who's who the SID/Quien es quien segun el SID.
All FTA open/Todo FTA, en abierto.
SatSearcher
West Yorkshire
Just checked this now, not even the slightest hint of a signal! Rest of 7 West A coming in at usual levels. 1m dish West Yorkshire.
Archive4
Also getting 7W as normal, except 11661v. Getting approx 2.5db with intermittent lock. Adjusting my position from .4 w to .4 e and I get full lock at 7.7db.
Could be my set-up as I´m still playing with the motorised 60cm until I have it fine tuned
( was watching MBC action when I noticed the thread ) on which I go from 10.3 to 11.3db when I put the position correct to .4 w
About the same for me as Alex in the CM 1.8 on 11.660V 7W. I have a long cable run though around 50 metres to the dish.
ocean04
Vaasa
Western Finland (63N 22E)
After acquiring 2.4pf and partially duo to cold weather here in Finland:
Nile-201: All, except 11727H and 11919H
E7WA NWA: All
E7WA ME-NA: 10719V, 12360V, 12418H, 12437V. Many others have signal, but under lock.
