Sagemcom DTR500 fan noise
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
HI ALL
I want to take the cover off the Sagemcom DTR500 to see if I change the fan to something much quieter. Can anybody tell me how to take off the cover?
Is this the DTR 94500 machine ?
From another site
In relation to the Sagem being noisy I have to say I encountered that problem & reported it to John Mc in ********* who got Kenny to check their own in shop device and with other customers none of which had the problem. Kenny rang me and suggested I move the box from it's current location in case it's proximity to another device (amp or DVD player) may be causing it to over heat. I have to say I was sceptical but I moved it and bingo the noisy fan is no more, so kudos.....
Is there an economy mode in which the fan does not switch on unless it is overheating ?
Tony1A
Moving it would not be an option. Anyway, I just wanted to get inside to take a peek. But I do know it has a slightly noisy fan and I don't use this box anyway as when I key up on the 2M ham band it makes the TV kick over to HDMI and then back again. Just curious that's all. :) An old Sky+HD box is no problem.
Terryl
Custom built PC
Several Ferrite beads or donuts on the HDMI cables will take care of that problem.
And in replacing the fan use one of the same size and DC voltage but look for the dBA rating on the fan, the lower the dBA the quieter it will be.
Here is a good place to start looking.
http://www.frozencpu.com/cat/l3/g36/c437/s1123/list/p1/Fans-12_Volt_Fans_by_dB-0_-_9_dB_Fans-Page1.html
At 9 dBA you won't hear a thing unless you have Dog hearing capabilities.
skomedal
This and that
thule
Moving it would not be an option. Anyway, I just wanted to get inside to take a peek. I don't use this box anyway
So just separate the top from the bottom along the grooves carefully with a broad bladed instrument, might be handy to pop the three tabs rear top first:D
Nothing too lose if just curious:-rofl2
Keep us informed of procedure please:)
Good luck
Regards
Not forgetting to carefully peel off the 'warranty void if removed' in one piece.
skomedal
This and that
thule
Just curious according to the OP so no big issue:-rofl2
Rip it apart:-lmao
Regards
Tony1A
Hey, behave yourselves! :D. I will probably sell it at the next ham rally, but I don't want to destroy the cabinet in the process.
