1.5 Precision dish install
Archived-1
Persona non grata
uk
Thanks again, if it does well with C band i will spend good money on a set up for it, i need to mod/make new arms first, one of my next jobs.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Oh ..it will work mate ..
I expect it would certainly match or even outperform a petalised 1.8 like Christina ...
Assuming the dish has retained it's shape..
Just dont expect miracles ...
there aren't any ..
lol
Archived-1
Persona non grata
uk
there aren't any ..
lol
Thanks Evan, i doubt that, i have no fear of it retaining its shape, if it is out i will spoke it up like a bicycle wheel and pull it were it should be :)
Archived-1
Persona non grata
uk
I've found a plan for a polar mount , i will make this for it this week :)
http://www.satsig.net/pol_ex1.htm
CROSSBONES
S.Wales
Ive not long binned a 1.2m precision with polarmount! You could have had the p/m. I have a feed horn spare here if you want it Martin?
Retired human
If it's the same Precision PM as mine was then it's a seriously heavy duty thing!
Archived-1
Persona non grata
uk
Thanks for the kind offer CB but I am fine thank you I have 3 now.
Finished painting the dish today and fitted the arms, ive also bought a few more actuators and a roll of coax and another ground stand and a new set of arms:).
DSCN0023.JPG DSCN0024.JPG DSCN0029.JPG DSCN0030.JPG DSCN0034.JPG DSCN0035.JPG
Archived-1
Persona non grata
uk
Well my mirrors have turned up, I just need the sun to come out now to check she's focusing as she should :).
sonnetpete
wordpress.com
Normandy, France
Archived-1
Persona non grata
uk
Stage one complete i will finish this tomorrow :).
I've found a plan for a polar mount , i will make this for it this week...
Martin,
If you need the specification of an original Precision heavy duty polar mount I have one that I can take the measurements from. It's rated for at least a 2.4 metre Precision dish and I think it may also rated for up to 3 metres or larger. The only reasons I can think of why it would not be suitable for larger than 2.4 metre would be if the circular steel fixing ring on the back of the dish did not match the polar mount fixing points. Or, if the ground stand pole diameter was too large for the polar mount to slide onto.
I have pasted a few pictures of it below, let me know if you need any measurements if you decide to fabricate one.
Rgds
Archived-1
Persona non grata
uk
Thanks again, the stuff they made for these dishes are way over the top the ground stands I have for the 90cm will be fine for a 1.2 and the fixed mount on the 1.5 will be fine for a 2.4 ally dish, I don't need to work to measurements I just visualise what will be strong enough and make it to suit, but yet again many thanks for the information and taking time out :)
Retired human
Yeah, that's the same PM I have... it's proper stuff. I was going to mount my 1.8m CM on it - it would drive it without issues. And might put my PF CM on it...
