16/32 APSK capable satellite receivers (was: Dr HD D15 16/32 APSK)
  • Thread starter Thread starter Archive-8
  • Start date Start date
Ok ..hopefully got a few sat positions in my SX6 now ..but only in ku atm ..
So does anyone know of a constant signal or currently active feed 16 or 32 psk signal between 45E and 45W I might have a go at locking in on Carl (my 1.5 offset )
There is a 16APSK feed up on 24.5W at the moment.....
11463 V 3583 5/6 DVB-S2/16APSK.
Did not find this or it is not on anymore. Balcony wall blocks 24,5W.
That feed has now gone, but another 16APSK feed has popped up
12692 V 2400 2/3 DVB-S2/16APSK "UKI-1903 P1 SD"
Showing a testcard. Breaking up a bit for me.
Nothing here not even jumping signal, maybe I need bigger dish. Could not find it with blind scan or putting in values manually. Blind scan list some transponders it can't lock, but this one was not in the list.
Can you clear this channel on 45 east 12526 V DVB-S2/32APSK MPEG-2 32720 3/4 Fox News Channel
Very strong signal here on my TM5502HD but unable to clear as the receiver is not 32APSK capable.
The 16E 12710V 16APSK 3/4 multi / single carrier needs 10.5 or 11.5 dB for error free picture. Jamie A has 12 dB with a bigger dish and is in stronger foot print area than I with smaller dish.
Nope, see post 19 in this thread. <a href="16/32 APSK capable satellite receivers (was: Dr HD D15 16/32 APSK)">16/32 APSK capable satellite receivers (was: Dr HD D15 16/32 APSK)</a>
Sorry for the confusion my question was aimed at Vipersan with his new Openbox SX6 as I would be interested in buying one of the boxes myself,
I gave my DrHD D15 to my Sister for freeview as I did not like it with the 45,000 symbol rate error & the data base was never as accurate as my TM5302HD.https://www.satellites.co.uk/members/vipersan.325666/
Sadly I'm in work atm ..so can't do any tests or checks till later ..
I just hope something in 16/32psk still to look for when I get home..
rgds
VS
rgds
VS
You will be able to get this if you dish reaches 45 east as it is active 24/7
Happy hunting with your new receiver :)
I had a D15 for a couple of weeks. I got one of the first ones just before Xmas and sent it back after new year couple years ago. It was less sensitive than my 50 EUR fta box. There was a problem frequency range at over 12500 MHz. At that time some eutelsat 28A over 12500 MHz tps were weak at Finland and I could not lock them with D15, but I had no problems with three other boxes. I don't know if firmware updates has fixed them since. OB SX is a little bit more sensitive than my Gigablue Quad which has it's own quirks. In my opinion one problem with DrHD and OB is support forums in russian (and GB in german) and the manufacturer is not involved. If you compare to fulan support forum their employees answer there.
So I'm guessing these feeds come and go rapidly ..
Just closed the shop briefly ..nipped home and tried..
24.5W
11463V 3582
at 3PM ..
Nada..
so looks like I was too late..
doh!
That Fox News signal on 45E is continuous ACM. I can only get broken video from it
24.5W
11463V 3582
at 3PM ..
Nada..
doh!
24.5W 11463 V is still active Vipersan, I just checked now. It's a two-channel mux.
Sorry the pic is blurred (rushing)..but just nipped home again in light of your post Jamie ..and input the parameters manually ..
Nothing ...?? not even a hint which I find very odd cos you are also in the UK..DSCF0054.webp
Perhaps I need to update firmware version to a specific version ?
If it is still active when I get home around 5:30PM ...I'll run up the TBS card and take a look if I can see it with that ..
cheers
VS
So ..I'm starting to wonder if this box SX6 actually can resolve high order psk ...
Are there more than one tuner versions ..
Nothing at all when I checked earlier ....or indeed just now...
but with the TBS card ..
No problem ??
rgds
VS
Have I paid good money for a pile of crap ?
Or is it a firmware version issue ?
Has anyone actually resolved this mux using an SX6 ?
My box is currently fitted with ver v3.01.50
Did you see box finding that transponder in blind scan? I can see the fox news transponder found at 45E, but it can't find the channel. I remember also seeing 16APSK data tranponders found in blind scan listed in flysat.
