46E (Azerspace 1)
360 TV Feed (Russian) -> 10960 v 5000 again active
Azerbaijan U21 - Germany U21
11042 h 10000 mpeg 2 full hd
Thanks for posting. However, please upload images to this site as it ensures that they are not lost if the hosting site goes offline.
sorry i have not noticed that option (upload a file) before. It is much more easier for me to choose that option.
thanks
11174V 28800 5/6 DVB-S2 8PSK is blazing in at just over 10dB this morning - no chance its on the Asian beam
Do you get the Ukrkosmos mux at 11039 V, AS? Comes in without errors here at 6.8 dB and that is apparently on the Central Asia beam
Yes. Jamie A got those 3 OK. Bit of break up. Comes around the 6dB mark using the 1.2 CM.
I was getting 14dB with the 100cm gibby 2 hours ago now no signal looks like it has either stopped testing or moved to the Central Asian Beam :(
11039 Will ?, it was a while ago when I checked,
Thanks for that info Martin,
The last hour of transmission the signal was going up & down so it looks like it may have moved to the Central Asian Beam or they had technical problems,
11039 V DVB-S/MPEG-2 3700 5/6 Ukrkosmos is supposed to be on the Central Asian beam & I get that with 7.2dB on the 100cm so CBC Sports may come back may come back.
Still no signals here on 11042 H 10000 just activated the blind scan to see if it has moved.
I am getting a studio feed now on 11057 H 4150 id=TV8-SNG @ 9.9dB
Hi, moved the 1.8 over here getting a few transponders on the central asia beam but not them all, a fair bit of cloud about atm I will check the others on a clear day.
EBC 1 stopped on 10991 v 2457 and started in a new frequency
11057 v 22710 5/6 dvb s2 qpsk2
i expect new hd channels in this frequency soon. (az tv hd, idman tv hd, cbc sport hd)
Maybe the long promised Kyrgyz TV will start on 46°E finally?
Anyway, 11057V seems Asia beam, can't lock it and dB reading is bad (below 2 dB ).
But today for the first time, I could lock and scan 11015 H, also Asia beam, at 6 dB.
CBC SPORT.webp CBC sport HD has started on 11175 h 27500
after testing just a few hours it seems that the channel stopped brodcasting
