1.5 Precision dish install
Archived-1
Persona non grata
uk
Hi, a few little bits to do then she needs to go on the test bed for completion, I will grab a quick hour before it starts going dark.
Archived-1
Persona non grata
uk
Hi, ive got it all back together, I had to take the boots of the bearing to do the welding there are now back in place and packed to the brim with grease, the bolt I bought for the elevation pivot is around 1 inch too small so I will pick another up tomorrow, ive grinded a bit of each side of the bearing to allow it to tilt fully back,
I now need to put the adjustment bolts near as dam it in the correct place and workout the best place for the actuator :).
DSCN0272.JPG DSCN0274.JPG DSCN0276.JPG DSCN0277.JPG DSCN0278.JPG DSCN0279.JPG DSCN0280.JPG DSCN0282.JPG DSCN0283.JPG
Archived-1
Persona non grata
uk
Looking very good now :cool: won't be long before you start to look for c-band?
Thank you Chris, well still lots to do pal but yes it should not be that long, its not stopping here its going at high level at the side of the 1.8, but I will be setting it all up were it is now, I best get my lnb etc ordered :)
Edit, Yes C band Chris, but I will offset a ku lnb
sonnetpete
wordpress.com
Normandy, France
Two questions Martin :
Why are you mounting a steering wheel from a tractor above the gutter?......Are the house foundations in tip top condition?
Archived-1
Persona non grata
uk
Why do peeps post something stupid/totally off topic when ive made/designed something good ? I would like to know :confused
I am sure it was meant in a jovial manner, Martin...
Serious question..(!)... Are the neighbours ok with the amount of dishes you have/will have up there? I know you have pp for the 1.8m but hope the neighbours don't start moaning about getting more than they bargained for...
sonnetpete
wordpress.com
Normandy, France
Martin, surely you know my whacky sense of humour by now...I'm full of admiration for what you've done and I know I couldn't have fabricated what you have...
Archived-1
Persona non grata
uk
I don't know tbh and not bothered what they think Alex. they will be a 2.4/3mtr for them to have a look at soon.
I know there is no malice Pete:) and your not on your own that do this:D I just wondered why it happens at the times it does, I guess its not important keep up the good work:)
I'd certainly be worried if I put up a 3m dish up without permission and then being told to take it down but the friendly council employee because someone nearby complained. It's why I am going into expensive trouble of getting PP for the 1.8m - my neighbours might move out in a few months to be replaced by someone less tolerant ...
While I don't care what my neighbours think either, they have the potential to be a huge nuisance if not dealt with.
Archived-1
Persona non grata
uk
I am past caring Alex, I will deal with any issues as and when they arise, I am totally aware of what I am supposed to do and not, the way to fit them is so they classed as a temp setup and nothing planning can do then :).
Have you applied for permission for two 1.8 ?, if not your in the same boat as me :D. but its nothing to do with me all I can say is good luck:).
samoloko
1.8 PFA
EU
Martin
how are you setting latitude of your polar mount - I can not see latitude adjustment rod
Hah... Nope. But no real plans for it yet. There's only really one good spot in my garden for good coverage and that's where the offset one will go.
Archived-1
Persona non grata
uk
Martin
Ok back on track:).
Hi samoloko, its work in progress I can only grab an hour on this here and there, I am also making this up as I go along no measurements to follow etc, so I need time to think and work out my next move, anyhow I now have it in mind how/what I am going to do and ive just picked the bits up for this :).
Archived-1
Persona non grata
uk
Hi, a bit more done and some work un done, I wasn't happy with the length of the pivot holder, so ive grinded it off and cut a slightly longer bit, it would have worked as it was but I am being particular here,
Ive drilled the pivot ready for the elevation adjusters, you should get the jest of what I am doing from the pictures below.
Archived-1
Persona non grata
uk
Hi, a bit more done on this. it might look a bit OTT, but this mount will be capable of driving a light weight 2.4 dish.
DSCN0310.JPG DSCN0311.JPG DSCN0312.JPG DSCN0313.JPG DSCN0314.JPG DSCN0315.JPG
CROSSBONES
S.Wales
Looking well beefed up mate! Looks the part!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Those eye bolts look suspiciously like the ones I used on Carl ..
are they I wonder ?
Got mine on ebay listed as gate hinges ..but sadly not in stainless ..
(10mm )
are yours ?
Mine were just galvanised ...
would have preferred SS and was prepared to pay a bit more for'em ..but they didn't do stainless..
rgds
VS
