Declination Angle
Chris, if you read through my Gibby thread, you'll see how I strung it and how I straightened it out. It's a very big dish and soft aluminium can get easily deformed during transportation, especially being at the back of the van for nearly a week.
If you have a large patio door, you can carry out the 'string' test on it
Archive-8
Still trying to find it. It's getting close to booting windows up!
Once I got the string and a bit of time I will have a go.
Archived-1
Persona non grata
uk
Hi Chris, to do it correctly you should divide the dish into 6/8 bits in the same way mentioned.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I think, if you can manage to do test on the mount, that will be even better. That is because when dish is installed it can change it's shape slightly under it's weight.
Archived-1
Persona non grata
uk
How did you get on with this Chris, my new dish was out on a flat surface i straightened it but still need to string it in the coming days.
Archive-8
The ball of string I ordered, hasn't got here yet, how do you straighten out the dish?
Archived-1
Persona non grata
uk
Ive got a big flat floor in the SH i just marked on the floor were it was out the braced a bit of wood across the two points and applied pressure then kept checking it until it all touched the floor, i still need to string it/large stretchy elastic bands it might need a bit more i will post pictures if so pal
Archived-1
Persona non grata
uk
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
I will be taking it a step further Chris and checking my dish this way, its the best way to make sure your lnb is focused :).
Morning M.....interesting.
¿Can you please advise what diameter circular mirrors you are using.......online have seen various on Amazon, the Bay etc ?
Archived-1
Persona non grata
uk
Enjoy your weekend. View attachment 84947
Morning D, I am using these pal, I had some slightly larger ones but my grandkids claimed them:), but these are fine, really made a difference messing with the 1.2 dish allowed me to place the lnd on the spot :).
Acrylic Mirror Shapes Square,Star,Triangle,Circle Mixed Pack Of 20
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Good work and thank you.......will order over the weekend along with other items.
Yourself and family be safe.
