New Inverto KaKu lnb
parkiepie420
technomate tm-5402hd m3 /gibertini 1.25m sat dish 51e to 34w inverto black ultra single 0.2db lnb / titanium single output cband lnb
technomate tm-5402hd m3/triax 1.1m dish 53e to 24w inverto black ultra single 0.2 lnb
sheffield south yorkshire uk
im trying to order one of these but I keep getting errors anyone else having problems ???
or is anyone else getting one of these and willing to order me 1 ????
Anonymous_1
I just a made a test and no problem.
don't foget to check these box (the last is the newsletter option)
parkiepie420
maybe that's where I went wrong ????
parkiepie420
ive done it ive purchased one of these lnbs I will post results of my finding as soon as I can !!!
samoloko
1.8 PFA
EU
parkiepie420
can anyone post a satellite and frequencies list location size of dish etc that they have received from this lnb to help people out when scanning for signals
just a thought ?????
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
And related to the above post, does anyone know if there are any Ka footprints which cover Ireland (east coast) apart from the RTE channels on 9 East?
I would be interested in getting the dual LNB, but it would be pointless if there are no broadcasters except RTE which have a Ka footprint here. I get RTE on terrestrial.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Looking at the footprint map of the 16E Ka band ...
this does appear to fall short of Ireland sadly ..
I know I have problems in Manchester ...and suspect these problems would worsten in Western and Northern Scotland...parts of Wales and of Course Ireland ..
My guess ..not impossible but a very large dish would be needed.
You may well be ok with 7E though ..as this is quite strong and doable on a 1Mtr dish over most of the UK I think..
To this end ...
Now that we have quite a few group members with the new Inverto Ka/Ku lnb ...
perhaps it's time to start a reception report list ..fot these 2 ka sat positions..
Reports welcomed in this thread..
7E and 16E channel reception reports plus dish size used and of course location ..
rgds
VS
I'll start ..
around 70% of the ka channels broadcast at 16E are lockable on a 1.5 mtr dish (variation subject to time of day and weather.
All Ka channels broadcast at 7E are do-able on a 1mtr dish ...but I would suggest a 1.2mtr minimum for all weather reception.
Saorsat at 9E is not possible regardless of dish size I suspect..
Receivers used include F15 ,SX6, and TBS card
Location Manchester
... good idea VS, and praps also add what receiver in use for the report. Iv'e tried two different models of Technomate rx on the same sat / channel, which both give a different reading.
Trust
Nijmegen Netherlands
Trust
do you recommend Ku Band Octagon PLL lnbs for use In fringe or there are other better than Oslo pll lnbs
did you test any other pll like Amiko premium L 104 or anything else
My findings are about the same as the BU .
My friend PaulvR told they are very good at the close together radio channels at 16 E
parkiepie420
hi everyone ordered the ka/ku band lnb on Thursday 291015 ive just signed for it !!! 02/11/2015 9.25am !!
I will post results on findings asap !!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
I am rx'ing about 50% of 16E KA channels...I am just on the edge of it....and all KA channels on 7E with a 1.5D
I just had a go at 25.5E (Es'hail1) and got KA-SAT-EVENT on 21421 V.
Ponny
Laminas AS 2700 H2H Mount, Eyvos 9515, Dr.HD F15 / F16, Azbox ME
Brandenburg
Hello there,
I once the feed cover of Ka + Ku Band LNB for receiving removed There were no receiving antennas available. At the end sits a ceramic plate or similar. Is anyone familiar with it?
Ponny
Post 251 from VS Ponny
That's the Ka probe area under the feedhorn opening Ponny ( the circuit board is translucent, almost 'see through' when shining a light over it).
Ponny
Brandenburg
Hello there,
there is an antenna. How is the horizontal and vertical reception with an antenna realized (V / H).
Ponny
Hello Ponny
Vertical probe is under the feedhorn.
Horizontal probe is through a polarization duplexer type waveguide under the circuit board (labelling wrong, sorry, transpose V and H - LNB sits on dish vertically).
That's why the LNB is wider than usual LNBs!
