Can anyone pick up NRJ Finland, very low SR?
Had a go with my old Nokia 9200s but no signal at all. Picture on TV is that of TYSA1 Channel on 12670H with a symbol rate of 260020160221_111818.webp 20160221_111818.webp
The 1st pic comes from the well known tool CrazyScan :)
btw. I think these reports are outdated ;)
Do you have UK type sockets in Malta as standard?
Yes. Always has been like that. Mains supply is 240V, Although it varies between 220 - 240V.
No, reports are up to date, I did them yesterday morning.
That could be a misunderstanding. I was referring to Lyngsat ;)
Lyngsat doesn't show the date for this narrow SCPC signal. According to Flysat the signal was reported on 04.10.2015.
For what it's worth, my Solo2 isn't touching that TP.
BTW, frequencies above 12500 on 5E are usually on FSS beam, rather than on Europe-wide or Nordic.
Hi, yes this one is receivable (in Southern Finland) with a PC and TBS5925. I will try with the same TSB tuner and my upcoming new Edision OS Mega receiver once I receive it
It's a difficult one for sure, at -20 degrees celsius it was easier, but now (+/- zero Celsius) its barely lockable
I think Octagon SF4008 manages well with this, however bear in mind that also several lnbs will not get that low sr either! So it's probably more like a combination!
Στάλθηκε από το LG G3 μου μέσω tapatalk.
