50E Turksat 4B
Archive4
For example Intelsat 28 @ 32.8 launched 2011 with 16 Ku band transponders only one in use,
Intelsat 25 providing back up @ 31.5 west,
Intelsat 16 on standby @ 76.2 west,
Intelsat 30 on standby @ 95 west.
Can I ask why?
These birds aren´t cheap to build, plus the cost of chucking them up there, why?
Can I ask why?
Back up capacity,
being off air is very expensive as Eutelsat found out with 16 east a few years ago & Amos @ 17 east has no back up at all after the satellite failed last year leading to lost revenue.
Archive4
That I can understand, but 4 birds for one transponder?
Riddle me this, riddle me that...............
11580 V 30000 1/2 DVB-S, is being switched on right now.
That one lasted only a few hours.
Right now: 10972 V (data)
pontiend
Contibruter
south yorkshire
I got this from a scan just now.It seems to be from there.
11445H.
TBS6983 100cm Dish.
Archive4
I can see Turksat Tanitum on 11471 H 2959 at 8.1 dB here on the 1.2 dish.
Any idea of s/r for 11445 H? Using stb not meter
pontiend
Contibruter
south yorkshire
10445H looks like a test carrier.Scanned with crazyscan.
It is still there.I get turksat tanitum at 10.5dB.on the 100cm Dish.
11445 H comes from the 51,5°E ... it is beacon the belintersat 1
pontiend
Contibruter
south yorkshire
Thank you Marcos_21.
A new one on me.:)
I did not know that I could get that.
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
My reception with 2.1m dish
Ive split these reception posts off the launch& testing thread.
Anyway - its very cold here this morning and Ive managed to lock Turksat Tanitim with a decent signal.
11472H 2960
Handy for when the next door Belintersat comes on air :)
EDIT - offset lnb on 1.1m dish aimed at 46E
A blind scan has picked up the Turkmensat channels at 52.5E :D
Lost Turksat Tanitim again :( The cheap lnb may be drifting now the sun has got onto it - the Turkmen channels are horribly unstable too.
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
The promo channel signal is very weak even in Turkey. It is lost and after a few minutes the signal reappears and then it is lost again. I get very strong signals from Afghansat with a multifeed system with 57 degrees east in the center with Triax 110, but cannot get stable signal from Turkat Promo. The signal may be weakened intentioanlly because the previous signal level for the promo channel(when it was on 11.595 V) was very strong.
satkingdom
Turkey
DSCN1270[1].JPG Good signal here with my 88cm mesh dish with no bleed over from other satellites close by.
satkingdom
Turkey
adonis1
I get Turksat tanitum at 13.1dB on the 150cm dish, with TM-5402 HD.
Orbitalzone_Delta
Multifeed & motorised
Istanbul
"TURKSAT TANITIM"
new freq. 11490H 2960 5/6 DVB-S
