36E Express AMU1 / Eutelsat 36C
If I knew I would tell you!
But with an estimated life until Q3 2017, I think there is not much more than becoming a backup, for Express-AT1 at 56°E for example.
I was hoping it would trundle westwards, so we could see some circular action from this bird here...
Back up for GE-23 / Eute 172A at 172E?
Hey Feedsat, any life from the Russian beam at your end?
What about 56e? There were some reports of Wide beam being received in Isle of Wight on 1.5m.
adonis1
Russian beam of 36 E ( circular lnb) with 5402 HD M3:
11727 L 10.5 db
11766 L 9.7
11785 R 10.4
11804 L 10.4
11824 R 9.6
11843 L 10.1
11862 R 9.1
11881 L 8.7
11900 R 8.4
11920 L 8.5
12035 L 8.4
12092 R 9.3
12131 R 10.8
12150 L 11.1
SatSearcher
West Yorkshire
Sorry for the off-topic question, but how do you get CrazyScan to show transponder details SR, FEC, mode Etc. on transponders that aren't locked? I can't get it to do that!
Anonymous_1
Scan results done with TBS6983 + CrazyScan 1.02.123
nelson_b
Contributor
11727 L 10.5 db
11766 L 9.7
11785 R 10.4
11804 L 10.4
11824 R 9.6
11843 L 10.1
11862 R 9.1
11881 L 8.7
11900 R 8.4
11920 L 8.5
12035 L 8.4
12092 R 9.3
12131 R 10.8
12150 L 11.1
Had a look here today --- using 1.8 channel master offset - with inverto white C120 twin + channel master feed
with original dielectric plate ( weather conditions dry but with some cloud cover)
held a lock on 2 transponders ok an 1 borderline
12092 R 7.6 db locked
12130 R 8.0 db locked
12149 L 7.9 db occasional flash of lock
Nice catch! Wonder if I manage something from there....
@pride21 - any luck on your side?
@Vipersan - have you tried this new bird in circular Ku? The old bird was just out of reach for you on the 1.5m.
Ive realigned my 36E dish (the 80cm on the tyre up the top of the garden) It had moved quite significantly in the gales over the winter.
Ive now got virtually all the Eurasian beam channels back.
Dewain is still absent atm & 12521V 1428 5/6 (Almasar Satellite Channel - not listed on Flysat) is ultra marginal, barely locking on an overcast afternoon.
New Russian mux on 11386H 28800 5/6 DVB-S2 8PSK (Sky Caucuses)
Ultra marginal on an 80cm dish here ( Ive jusyt got enough signal to scan the schannels)
The channels are shoehorned in - there are around 30 of them! Most if not all encrypted - Trophy Crypt according to Flysat.
Interesting. Wonder if my still active CAM will open them. At least I think it's still active. The quality on 46e of these was awful.
Strong signal on the 1.8m but my dusty Trophy Access CAM isn't opening them despite showing available balance. Maybe I need to update it...will leave it overnight and see what it does.
My eyes hurt.....
MCelliotG
Thessaloniki, Greece
I receive it with 13.5db, fairly well! However the whole transponder is a mess, most channels seem blank even though they are flagged with TrophyAccess encryption. Even the four FTA not only are unwatchable, they are named wrong!
