- TM 5402HD
- Scottish Borders
Greece is well short of the official footprint. However odd things have been known to happen in extreme fringe reception, so give it a try.
Receiving 27.5W with SmartDVB 4.0.24 (Beta 1) + vplug 2.4.6 + TBS6983. I set PMT, audio/video PIDs etc; SD channels work just fine, however, I can't get the HD channels to show. I set video to streamtype 27 (H.264) and audio to streamtype 17 (AAC), but they still won't run. Audio seems to be detected ("2 chn, 0 kbps, 0 Hz" is shown) but video will not start, only a black screen. H.264/MPEG4 channels on other satellites play just fine. Any clue?
best regards,
Tamerlano
![2016-03-07 20_40_57-SmartDVB _ Prof 8000 BDA DVBS_S2 Tuner_Demod [bda.dev].webp 2016-03-07 20_40_57-SmartDVB _ Prof 8000 BDA DVBS_S2 Tuner_Demod [bda.dev].webp](/data/attachments/77/77142-7423b0da24d0668d8363c548131566aa.jpg?hash=Vm1qH5eynu)
best regards,
Tamerlano
Have a look at this page for settings. You need video as MPEG 4 not H264.
FlySat Intelsat 907 @ 27.5° West
Which elementary stream type would that be? Odd, the previous commenter successfully employs 27 (H.264) for video and 17 (AAC) for audio. Anyway, I tried to configure each of the HD channels last evening and I only got ITV HD fully working with the 27/17 stream types. Will check if the correct k$@ is loaded for each channel.
Have you tried to change decoders? Settings-directshow-connections? I use Microsoft DTV-DVD Video Decoder or Lav video decoder also as h264 decoder DivX one works fine.I can't get the HD channels to work, not even ITV
According to my DrHD F15 receiver it is 544x576i and judging from the picture quality I would say that is right.Film 4+1 (which is actually a 1920x1088 HD channel, contrary to information on Lyngsat and Kingofsat)
I wonder if there is enough space to squeeze Channel 5 HD into this backup as they are now testing on the Freeview PSB3 mux?
