- Jul 26, 2003
- Location
- Scottish Borders
- Scottish Borders
Please post any details of 16APSK & 32APSK feeeds on this thread
IMHO this is a typical carrier example that shouldn't be posted in this thread.5.0W-11448 H,1703,5/6,Dvb-S2/8/32APSK,CCM,stream Generic,Single-Sky TG 24 HD,Regular prog.
I get the exact same problem with this channel and TBS5925, SD resolution and broken picture with the signal above 18db! Could it be that it's broadcasting like this?
The state diagram shows only 8PSK ;) If the modulation is switched between 8PSK and 32APSK it can't be CCM. Further it says continuous. You won't tell me that you can watch the video. You can't even produce a clear screen shot though CNR is more than enough. There are boards where this kind of feeds (ACM, continuous) are shown but nobody can watch the programs
..no, the header is wrong because it can't be CCM by definition. And again stream type is continuous -> not watchable.And I don't think apps read the stream incorrectly
What is the required C/N according to Shannon? ;)but the new ratified standard dvb s2x introduces apsks up to 256 spsk!
Hello
Feed active on 8.0w
FLAVIA 6B
<transponder frequency='12506000' symbol_rate='4149000' polarization='1'fec_inner='3' system='1' modulation='4'/>
EUTELSAT 8.0 W 12506 V 4149 3/4 16apsk
I have sound but not picture
Italian feed as i hear
OK whats the consensus on changing the thread title?
Doesnt matter to me - I'll change it to whatever you guys want although I suggest we keep in "
16/32 APSK" maybe with the modulation details after this bit.
Feeds only or transmissions instead??
