50E Turksat 4B
Two transponders switched on, both with TURKSAT TANITIM both no picture yet:
11480 V 25000 8PSK 5/6 (16 dB here)
11522 V 25000 8PSK 5/6 (15.5 dB here)
satkingdom
Turkey
10 fixed offset antennas ranging from 107 cm to 170 cm with multifeed systems on them.
Next Machina3D Satellite Receiver
North-East of Turkey
I could not get any signal from Turkey.
adonis1
11489H 16.1 db - no picture
11480 V 2500 16.6 db - TURKSAT TANITIM demo
11522 V 25000 16.6 db - TURKSAT TANITIM demo
Kveys
Southern Finland
(11489H stabile 9.6 dB ) but these new ones 11480V/11522V only about 8 dB and no lock.
Archive4
I´ve lost the stored Turksat on 11488 H 02959, zilch!
11480V 25000 12.1 dB
11522V 25000 11.7 dB
Both have ( the same ) audio and video
Both blazing in here at 12.5dB :)
Offset lnb on 46E 1.1m dish
Kypros_Pambou
TBS:6985,6925,5925usb
5 Pace&Arris IPTV Gateways
Greek Cyprus
Both freq (11480 & 11522 V) around 17.5-17.6dB with 2.1m
satkingdom
Turkey
Getting 3 active transponders this morning,
11479 V 25000 Turksat Promo
11490 H 2220 Test carrier
11521 V 25000 Turksat Promo
11480V & 11522V appear to have been switched off (although heavy rain isnt helping dxing here atm!)
No signals now from 11480 v but 11522 v may have changed to NS3 as showing green in the spectrum ? but no lock on this with the TM F3/5 + 90cm
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
william, you need to do one of your famous tutorials on the spectrum analyser, as I suspect many do not use or understand this.
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
What are the 3 peaks at the bottom end of your spectrum?
I will check again with the TM5302HD
The spectrum analyses on the TM F3/5 is not very detailed the TM5302HD is better currently shows only 2 horizontal transponders 11467 H & 11490 H 2220 No vertical transponders active.
I will not be using the spectrum analyser on the TM F3/5 again as I think it is misleading.
Two tps back on air both showing Tanitim:
11197V 2220 9.2dB
11491H 2220 12.8dB
pontiend
Contibruter
south yorkshire
Tanitum is alive and well coming in strong too.
TBS6983 100cm Dish.
Kypros_Pambou
Greek Cyprus
Strong signal for TürkSat Tanıtım (11196 Ver )
Kypros_Pambou
Greek Cyprus
My strongest reception ( until now ) with my 2.1m dish !!!!!
popovp
My system:Receiver-Ferguson Ariva 102E HD, Sky Sat 9900FTA+emu;Ferguson FX-6600CR/OCTAGON SF318 soft;LNB-Sky Sat, universal, 0,2dB;1.17x1.06m offset dish ;Diseqc 1,2 +USALS Moteck2100A motor; 1,2m parabola+0,3dB Inverto @ H-H Strong SRT DM 2100
Varna, Bulgaria
Here with 1.2m. Max SQ indication of receiver SD sygnal 75%
pc screenshot
popovp
Varna, Bulgaria
