which program can lock Kaband Freq and play encoded channels ?
alaa2003
tbs5925
lenovo y510p laptop
Kuwait
Hello
i would like to lock kaband transponder to play channels
one of channels is encoded with Biss
so i just need to know what program is suitable for that process ?
1) Do you have a suitable Ka band lnb? (4 different bands are available in Ka band)
2) are you within the coverage are of the Ka band channels you wish to receive - many are transmitted on spot beams
3) cant help you with keys on this forum but various sites carry biss keys
alaa2003
tbs5925
lenovo y510p laptop
Kuwait
1) yes , inverto KuKa
2) yes i have coverage, i can receive FTA channels normal
3)NP , just need to lock it
Just set the appropriate local oscillator frequency on the receiver & tune the channels in as normal.
Which channels on which satellite are you after?
alaa2003
tbs5925
lenovo y510p laptop
Kuwait
i am using tbs5925 dvb card
channels located on Nilesat 7W
You still need to set the appropriate local oscillator frequency - presumably there is a 2 way disecq switch inside the lnb as its twin band?
If so Ku will be on one port & the Ka on the other.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Nilsat 7W 201 @7.2W am getting the KA Band 21462L 22500 5/6 With New Inverto KA/KU LNB. Strong Signal.
Interesting ...... i'll have a look to see if there is any signal coming our way to the UK but think i will struggle with not having circular capability.... yet, but looking at the Ka footprint it seems to come nowhere near us in the UK.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
John I don't have circular capability...it's just the power is quite strong. Even the footprint
according to fl*sat doesn't cover this part (Malta)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hmmm ...
I'd check this frequency myself ...but cant atm ...
on account all expensive LNBs have been removed from my dish until the lightning threat for this afternoon has passed ..
The last session of Donner und Blitzen was too close for comfort.
Tomorrow maybe ?...but doubt if there was even a disturbance in the trace as it were..
I had a look earlier, I couldn't lock anything
