There's a mechanical workshop nearby here that can make me anything needed, for the final install I'll put in an order. ftm am just looking for a quick fix to test dish\placement\orientation.provide any diameter cut to length
Don´t suppose a neighbour has a 2cv you could borrow! Used to be nicknamed the mobile deckchair!^^^ Excellent, looking for ideas involving chairs, trees, pieces of rope & wood etc :O)
The approx 19° elevation here will make the dish forward heavy afaik. Got a house wall close to the rear at the intended test-site, to which I could fit adjustable cargo straps to the dish rear mount.
There's a mechanical workshop nearby here that can make me anything needed, for the final install I'll put in a order. ftm am just looking for a quick fix to test dish\placement\orientation.
Yes, that dish is another league to what I am acustomed to, but it should be possible with a little thinking and some good tips.Difficult to temp fix with that size dish I would say.
Good point. Plan is to make it too simple, very ugly & cumbersome, to be sure it's temporary :O)When you make something temporary it will automatically become permanent.
