My SAT-playground
Which hole is the wife in?
RimaNTSS
Some SAT-related hardware.
N-E from Riga
After 2 days under polyethylene IMG_20160720_163552 (Custom).jpg , removed the mould. IMG_20160721_183013 (Custom).jpg
Surface of the block is not perfect and there are some small cracks, which are not deep.
Will let it dry for couple more days before doing something else.
2 @Lazarus : same wife is still around. She was quiet angry to see this concrete block. I just wander what she will say after "small" antenna be installed on the block :-buttkick
Rimant, do you not tell her what your plan is until you've done it?
He's been married longer than you, CJ! :D
Exactly, so I am trying to learn the tricks of the trade. It's not like she can make him remove a 4.6m behemoth.
BTW, G, that's a worrying avatar you have...
Yes, it upsets me too!
I'll find a new one .....
Edit: There you go ;)
RimaNTSS
N-E from Riga
No, she does not know about antenna, but maybe suspects something :D. She likes surprises (I think.... I hope :-doh). Should I present her perfume?
Smoked Fish would be better.
Does she not look inside your garage and notice you shiny dishes on the wall? And wondering why her hair products don't last very long?
archive10
When the pre-fab house people slap-up houses around here, they let the concrete base set for about 4 weeks before they put up the house....
Not that this may transpose to your sat-plinth, but it does indicate that large plunths make take some time to cure...
RimaNTSS
N-E from Riga
people ...... around here
They probably Estonians, they do everything very slow (I like jokes about my neighbors). But, seriously, I will do some angle grinding work tomorrow or day after tomorrow, and installation of the mount will take place only next week.
RimaNTSS
N-E from Riga
Did some dusty work today on the edges of the block..... 14 meters only :eek:
nelson_b
Contributor
I can imagine that it "was" a pretty dusty job :eek:
Looks like "good quality" concrete that you have put down there :)
Better than mine shite, that's for sure!
Archive4
Please specify mine shite, universal translator does not compute!
Boolean Nand or Nor would be more appropriate on this occasion!
I hate my phone. All it does is make spelling mistakes.
Anyway, carry on.
Terryl
Custom built PC
After 2 days under polyethylene View attachment 95442 , removed the mould. View attachment 95443
?? Why did you cover it ??
Terryl
Custom built PC
No load about 3 days to walk on it, light load 15 days, heavy load 28 to 30 days, pre-stressed load 6 to 12 weeks, bridge supports 6 months.
RimaNTSS
N-E from Riga
RimaNTSS
N-E from Riga
Received phone call from my neighbor this morning. He was wandering why do not we try to erect Andrew Pedestal?! That is the same neighbor who will see my antenna all the times, that will be his main view from majority of windows :D. I did not mind, and we moved pedestal next to the concrete block. Those 2 parts are quiet heavy, we managed to join them together but stopped at the point how to lift the construction :cool:. Should find the solution. One of the options could be to drill couple of holes in the block (yellow) and fix eye-bolts there and then use ropes or winches.
