- Oct 21, 2006
- See signature
- North Somerset
Maybe hire a crane? What does your wife have to say about your latest erection?
She has made no comment since, throat is still sore! After all the swearing last time!Maybe hire a crane? What does your wife have to say about your latest erection?
It's better to just keep it wet and let the heat out, the only time you should cover it with anything is when the air temperature is below zero, you do not want frost damage, also the forms should have been removed the second it was hard enough so you could not press your thumb into it.That helped keep surface always wet and helps concrete to cure more evenly.
And be-leave it or not concrete never quits curing, Hoover dam is still curing, the Roman Colosseum is still curing. (The Romans invented concrete, I helped mix the first batch)
@Terryl , I see you have lots of knowledge in this field, which I do not have. I spoke to local specialists, and followed their instructions . They practice the way of polyethylene cover also at summer time. Anyway, seems that my slab is doing well. Will not dig it up/ break it and start everything again. I already had enough pain, and some pain is still coming.... I know there is some hard work ahead. I will just try to not make fatal mistakes on the way.It's better to just keep it wet and let the heat out
It will loose something in the translation but,...(V)CL Anno natus sum, et habere in bonis cursare.Nam quot annorum es ?
Yes, it is up. I've posted picks earlier. ;) Will try to install this antenna without too much investments, so no rentingHave you tried to raise the pedestal yet?
...................Agreed, we all admire his projects and input, inspiration to us all or what..............congrats.Rima you are Insane sat freak
but I admire you
