Lyngsat is now listing two TV channels in extended C Band from 65 W.
4506 V 5000
4510 V 2083
Unfortunately, I have strong terrestrial interference from 4500 to 4510 MHz. I can see the 4510 V 2083 signal on a spectrum analyzer, but the interference prevents me from locking it. Anyone getting these?
Yes, i also spotted the extended Cband frequencies listed last night. I might just be able to squeeze around to it, i will see if there is anything coming our way into the UK
on 4510 V with good signal for a 1.8 CM4506 V is weaker but I don't use the appropriate Cband stuff yet...
A fine tune adjust will be necessary
View attachment 95567 View attachment 95568 View attachment 95569
Yes John, nothing yet in H but probably more frequencies will be activated soon, this satellite will be used for RIO Olympic Games Contributions.
Hum, the official frequencies for the telemetry are 10,949.7 and 11,200.3 MHz. There are also unmodulated carries just inside the band at 4500 and 4800 horizontal. Not completely sure about the 4500 one because of the terrestrial interference here.
------------------------------------------------------------------------------------------------------------------------------------------------------------------Ok thanks ..... i'll investigate a bit more
@lost_mesa ...... found the source of the mystery carrier at 11.520V. This seems to be coming from a source across the road from me at an Infants school ?? but will look into it further.
I have found the two official beacons at 10.949 H & 11.200 V on the analyser but they are not very strong, thanks for the info.
Further to last ..... and i'm 25% sure i'm not loosing it, BUT-- on the same position with no inclination adjustments are two more beacon like sigs which do not have the same characteristics as my mystery one.
These are: 11.701.1 H & 12.199.8 V. Anybody else to have a look to see if they can see see them ?.
Which LNB are you using?
-------------------------------------------------------------------------------------------------------------Which LNB are you using?
The JRC one Graham, thought about dropping the modded TiT on tho for a look.
Actually probably not a bad idea to try a swap comparison , the signals have dropped a tad
