But then I stumbled apon this:-
Unfortunately that is not possible, as one side of the drive hasn't got a wall or fixing post.Not cheaper just to put a heavy duty chain across the gap?
No there is a gap going from 31/2" to 12" between the driveways.So, is it possible that a really dedicated interloper could enter your neighbours drive and perform manoeuvres to wiggle across into your drive despite the Bollard?
They look fairly level from my perspective, but as we all know, looks can be deceiving. Especially after 4 glasses ( may have been litres ) of Sangre de Torro.Unfortunately that is not possible, as one side of the drive hasn't got a wall or fixing post.
That's my brick upright on the left. The stubby bit of brick work on the right is next doors.
What you can't see in the photo is the driveways are not level with each other.
Alternatively, you could mount a dark motor and a rope, and using a decent receiver play " Brown girl in the ring " all day from the living room, using external speakers of course!
It is 1hr minimum anyway. But the cctv captured them turning. Fitting the bollard & changing the wheel.See if they charge you for the time they took to change the wheel.
Mind you, they probably invoice for an hour at minimum anyway.
Not much point in being half covered is there? Needs to be the dogs bollardsFully comprehensive, I imagine.
