Sky Q LNB Question (sorry if its been asked before)
benwiddowson82
80cm dish (Amiko Motor). Amiko Alien2+, Amiko Alien Mini, GigaBlue IPBOX, Ariva 203, Sky+HD 2TB, NC+, TNTSAT, MTV Unlimited Cards. Mac Mini, MacBook Pro.
Loughborough, Liecestershire, UK
Hi
I just have a quick question regarding the SkyQ system and its LNB. I take my Sky system touring with me around Northern Europe with the aid of a Triax 64cm dish and a Inverto Black LNB. If i upgrade to Sky Q can/will the box run on a standard universal LNB for a short time (i'm not so fussed about limited functionality as long as it will allow the viewing of one channel).
Ben
From what I've read $ly Q uses a wideband LNB which is not compatible with a universal LNB or vice-versa. I'm not sure of the intermediate frequency of a $ly Q LNB but I doubt it's the same as either of the IFs of a universal LNB so would not give even limited functionality.
So, I think the answer is no.
It would be very shortsighted if the design of the SkyQ receivers did not have a local oscillator adjustment within the menu to cope with existing dish requirements.
The Sky Q box on a domestic installation requires a wholeband LNB with Vertical and Horizontal feeds, if used on a an IRS in say a block of flats, it uses a dSCR (Digital Satellite Channel Router or Digital Single Cable Router) feed, it may be possible to get one working on a unicable LNB, but you'd need to change to dSCR mode and change the SCR channels in the setup menu, as unicable uses fewer channels, only 1 to 4.
benwiddowson
60cm FTA set-up / Mac Mini
Leicestershire, UK
I'm assuming the safest bet is to stick with SkyHD or take a freesat box with us next time.
jimmypegasus
Sky HD
North West UK
Hi
Ben
You will not be able to connect your sky q box to a standard LNB as they work in a completely different way. Only option is use an old Sky box or freesat for free to air channels or a Sky box and temporary swap your card from he sky q box to your other box. You
can pair the card to your box in one of the menus. The only other alternative is to tap up a sky engineer to see if he will sell you a hybrid lnb ( has 6 connections, 4 for standard fix and additional 2 for skyQ) or one of the new sky Q lnbs. I can go into greater detail if need be why the 2 LNBs are not compatible.
ATB
JP
