Surely Hedgehogs are limited to 10m/hr?
Well done!Today, at ~8:47 got first lock, that was 28,2*. But, of course, need lots of fine tuning. What, party tonight?! ;)
Splendid! Excellent job!Today, at ~8:47 got first lock, that was 28,2*. But, of course, need lots of fine tuning. What, party tonight?! ;)
Perhaps you're going to need multi-LNB setup to receive both 2E (28.5) and 2F/2G (28.2)Today, at ~8:47 got first lock, that was 28,2*. But, of course, need lots of fine tuning.
It's probably like that classic Simpsons episode when Homers rough as a badgers arse at the breakfast table and Bart asks him what happened the night before, que his memory of the night being shown like a black & white silent film with drinking at the start then at the halfway point a static card saying "Scene Missing" then it abruptly ends with "The End" titles lolThat must have been some party
How about an update on this?![]()
Yes, truck came behind the greenhouse and filled up about 5 m3 of cement, means about 12 tons.How did you make the concrete for the platform?
All 8 of them have consumption of ~5kWt.![]()
No, did not do that. Dish was not finished (even segments were not fixed properly) and I did not want to start making measurements under such conditions.Have You measured C/N on weak channels 28E ?
Did You catch any UK beam channel without second mirror.
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Made couple of plates to fit on original flange of the waveguide. Through those plates will let tunable axis which will skew LNB and also be possible to adjust LNB closer/further to the SUB. Will try to make fork for C-band LNB and, if needed, will fix Ku-band LNB inside. I understand that at one time I will have ether C or Ku installed, but, can not figure out how to make mechanism for changing of the LNBs (I mean, LNB-changer).
