Yes, most of us have tried the Black Ultra at one time or another.
Pros and Cons, as with all other LNBs.
Long neck is useful as it gives more scope for axial adjustment.
But longevity can be a problem. My own failed after about three years, but others report even more premature failure.
The big draw when they first came out was sensitivity, and they're not bad at all, on the whole. Others have caught up.
axial adjustments ? Pls. elaborate..
I find they work well and haven't had any issues with longevity but most of mine are probably only a few years old. Mine seem to work better on longer cable runs for some receivers like the DRHD F15. On shorter cable runs I've had to use an inline attenuator to turn them down a little.
turn them down ?![]()
Never heard of someone wanting to reduce the signal strength.
I always thought, d more the merrier. ;)
It may sound odd, but I got better quality signals on weaker transponders when I used an attenuator. I was able to lock transponders that I couldn't get before. This was particularly noticeable on high end frequencies over 12.5GHz back in the days when Astra 2F 28E was using them and with Astra 1N at 19E was weak in Finland. Perhaps some of the very strong signals from lower in the band where drowning out the much weaker ones higher up in the band. I used a variable attenuator so I could watch the signal quality levels on the receiver while I turned it up or down to get the right balance.
