uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
MarkW
1.2 Galaxy,IBU single,Technomate 5402M3
Jesi,Italy
Oh.That's the first time I've noticed red button missing.Comes up with Scrambled Channel now.
MarkW
Jesi,Italy
There's Rb0 (vpid 701,apid 702 and ppid 701),sd channel now.Apparently there's still a Rb1l(vpid 901,apid 951 and ppid 901) which I think is the original Red Button but comes up scrambled for me.Tried manually entering and linking to key but still no show.
Nagusia
Gibertini 0p150 with single Inverto Black Ultra plugged into Humax FOXSAT HDR | Portable 80 cm dish with IBU plugged into TechniSat SkyStar USB HD DVB-S2 receiver/W7 64 Media Center / ProgDVB setup.
20 km south of San Sebastian N Spain
Red button is back.
Yes, Red Button works but I can't get BBC Four HD to work. I just get a 'no audio, no video' message and a black screen. Are they still emitting anything on Vpid 7601,Apid 7602,PPid 7601? I was away for the Olympics so I don't know if it would have worked before.
Things will have gone back to how they were before - BBC4 doesnt start until 1900uk time.
Eusebius Punz
Oberndorf, Lower Austria
Wavefrontier 30" W - 28,2" E
Oberndorf
BBC 4 HD should start at 7 p.m. uk time, 8 p.m. timezone +1.
That's European time - 7:00pm UK time.
Retired Mod
www.timo.me.uk
BBC 4 HD will most likely have gone from this mux now that the Olympics have finished and it's switched back to it's old home.
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Good evening
Is anyone able to see these channels using a cam?
I'm looking into programming a transmodulator to distribute the channels but would need a working cam.
Trigger
radicaldoc
1.2 gilbertini with VU+ Solo2. 60cm with Spanish TDT from satellite.. and channel master 1.0m for 27.5 hopefully..LOL
Horizon USB Plus
Nr Martos, Jaen. Spain..
Hi i am on a 1 mtr old Tooway dish down in Jaen andalucia and have no problems at all except usual very bad weather...
wanderlust
1mt dish and trypod - icecryptS1600CHD Receiver - Satlink WS 6908 meter
UK and most of Europe
Perhaps some kind people can update me on dish sizes needed for Intelsat 27.5 deg W....?
Specifically what size might be needed near Perpignan (border of Spain and France, eastern end) and also in Alicante...?
I ask because when I tested the signal in mid France in 2015 I had no trouble getting it on a 60 cm dish - not really strong but certainly working 99% of the time. However in October 2016 when I tested it again the 60 cm dish really struggled to bring in the signal at all, and the slightest rain or thick cloud knocked it out. I seem to remember that others have observed that the signal doesn't seem as good as it used to be....
In my case in mid France the situation is academic as Astra 2E romps in, but I've been asked to advise for Perpignan and Alicante so hope some folk with local experience can give a bit of help.
Thanks!
I use a 95cm dish which works fine down at Alicante and all of France, Germany,Austria but was borderline in Groatia when we had slight Rain.
nwaggy
1200 dish twin lnb full sky plus 907 to keep her happy
nerja costa del sol spain
mw963 iam in southern spain nerja malaga province using a 800 dish never had any problems except in a heavy rain storm
Adam792
Cheltenham
Good evening
Trigger
I think if you search around you can buy a BISS CAM for receivers/transmodulators. I've seen one for sale before.
Seeing as the DVB tables are all encrypted you'd probably have to work out mapping the PIDs first though in order to decrypt the data and transmodulate it.
Sent from my iPhone using Tapatalk
Thanks!
Alicante, easy on a 90cm dish. But why bother if you can receiver 28E on a 120cm dish.
Eusebius Punz
Oberndorf
Thanks!
The flootprint says for this Region a 80 cm dish should work. The high FEC with 9/10 is very sensitive. For me the Signal goes down 15 percent and more in bad weather. This Region is outside the 120 cm beam from Astra 2 Spotbeam.
Thanks for the further input. I think that at both locations 120 cm dishes have been tried on Astra 2E and found wanting. But I am a twerp, I may have meant Andalucia which I believe is definitely not going to work on 120 cms for Astra 2E.
I'm afraid my geographical expertise is higher for France than it is for Spain.
But you've all told me what I need to know and so renewed thanks.
Depends what part of Andalucia. Some of it is possible with a 1.8m dish but most of it is completely impossible even with a 2.4m.
BLUEPLATINUM
Maspalomas, Gran Canaria
120cm in the Canaries. 140cm if you can afford it just to add a bit of tolerance.
Sent from my SM-N910F using Tapatalk
