Just Sharing This MBC to badr 7 tonight
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
badr 4:
11,919 h
MBC package is to be changed tonight from badr 4 to 7 badr
is likely to disappear in Western Europe
Source: technical assistant MBC
Boooo! It's a nice package....
Ah, well.
Time to unearth summat new.
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
about badr 7 he said :
We (MBC Group) have rent capacity here for some of our programs
maybe not all programs will disappear
Laser
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
hoi,
badr 4:
11,919 h
Still not convinced anything has happened yet!
Referring to the other thread re: Badr 7 tests:- va 227 badr 7 26e
nothing seemed to show here on any of the mentioned frequencies and we def should be able to receive them in this location according to footprints.
¿Scan yesterday and today show no real differences so has the change taken place?..........as:-
Anonymous_1
Same situation here, yesterday's evening scan and this morning
Yesterday:
This morning:
If it has changed over to Badr-7 then the signal here has improved on my 88cm mesh dish + TM5302HD set up.
No difference here - signal as strong as ever.
Active transponders received from 26 east with my 88cm dish set up this is what I normally receive but the signals are a bit stronger today.
100cm +TM5502HD on 26 east
I lost 11149 H 27500 some time ago despite feed back that some members further North than me are able to get this transponder it still alludes my set up o_O
No issues with 12149H here - as strong as the MBC TP.
Laser
Very strange. I did have 12149H here all OK. Channels are loaded in receiver. Gone now. Not sure what the explanation may be?
It looks like the footprint for 12149 H 27500 is less favorable from Essex to Berkshire maybe this is Badr-7 ?
Sorry about the frequency typo error in post # 11:oops:
Badr-7 - Arabsat
I am getting 15dB from 12149H (on the 1.8m) - I really doubt this is Badr-7 if the maps are to be believed.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
12149 here, from Badr 4, is more or less showing the same dB level today as 15 months ago.
Wonder if your U.K. reception of Badr 4 is now affected by the Astra 2F frequency of 12149 H 27500, both now have a FEC of 5/6. In March 2015 the 2F 12149 was using a FEC of 2/3 but in June 2015 was using 5/6..........Astra uses DVB-S and Badr 4 using DVB-S2.
Still convinced at the mo that Badr 7 is not being used for replacement transmission.
Using a 1.2m for the Badr reception.
Archive4
I'm getting 15.4 dB on the 1.2 m now. Until I checked , due to this thread , I had nothing! The Xtrend had it as 30000 not 27500 :-ohcrap
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
........ Until I checked , due to this thread , I had nothing! The Xtrend had it as 30000 not 27500 :-ohcrap
Hi Brian..................yes a scan in September 2015 still showed it as using the SR 0f 30000......do not know exactly when it changed to 27500.
This is the MBC official footprint for Badr-4
As we know reception is possible well outside this.
