Dongles.....
Archive-8
What is the main reason for using a txco dongle?
And what is the main gain, compared to a regular dongle?
Many thanks.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
TCXO stands fot Temperature Controled Crystal (XTAL) Oscillator ..
Unlike conventional Crystals which can drift a few 10s if not 100s of cycles ..
TCXOs use a constant temperature crystal oven ..
ie ..maintained at a more constant frequency ...some as low as 1 cycle drift over many 1000s of hours of use ..
Since the dongle uses a fequency multiplication this error can show up as substantial frequency drift ..which is minimised by replacing the XTAL with a TCXO..
hope this simplified explanation helps..
Archive-8
Yes thanks, that explains that.
Looks like I need to keep an eye out for one of them.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The same design -usually sold as a dvb-t stick - appears to be in the sub £10 offerings on amazon.
Any claim on stability/sensitivity is to be taken with a large piece of suspicion, no matter where they come from.
Archive-8
I have a "cheap" one at the moment. But I have ordered one of these
And it's the newer R820T2 chipset.
Supposed to be more the über dongle, or the rtl-sdr dongle @Vipersan and @Llew have.
Chris you dont have to take Milamber too seriously ;) :D
Im tempted to change his user tag to Forum Jester :D
