Portable satellite dish base
blademedia,
What were your impressions of the Evolution MAG drill that you bought before the Rotabroach? Was it simply not up to the job or not particularly well built? The Rotabroach seems to be making easy work of cutting the holes, especially with a good quality cutting bit.
Rgds
nothing wrong with the evolution nearly bought it good reviews but not multi speed very slow speed is needed for hard steel if your drilling mild steel as I will be after this job go for it
its getting near to the time for seeing how much extra weight needed to reach my estimated 1.3 tonne working on this
I have 5 lengths precisely 6ft each 6x5=30ft 30ft = 10 yds 10x125lb =1250lb 0.5669905 tonne other steal work to install should just take it under 1 tonne so some paving slabs needed please correct me if make maths mistake it late and had a bottle of wine :-doh
:dwinkies:
blademedia,
A UK imperial ton is 2240lb so there is a very small correction to your figures, 1250lb = 0.558 UK imperial ton, minus the weight of the hole plugs that you cut out. I hope you enjoyed the wine.
:dwinkies:
Rgds
containers turned up today with dishes in will get the 2.4 out tomorrow ready for instillation
dish out and cleaned I make az/el mount to polar ive done conversation before very easy with this type
I make this
2-4m-_az-el_grey_background_12__flip-_1aa-jpg.98435
as you see I have two main parts to start with only have to make moving part
all parts ready for installation pipe cut to 3ft pieces
img_2655-jpg.98094
8 pipe on each side due to the weight will be built up in place
need to start ground work now putting concreate sleepers in place need 6 strong men to move them
And as this mount sloooooooooly sinks into the center of the Earth due to the creation of a micro-mini black hole we say good by to..........................Oppppppps too late. :-woohoo
looking for 6.62 pole no luck continue search later put most parts in place to see bolts needed for levelling system
6.62 what? You state 2ft long, but 6.62 ft wide does not make any sense , neither does 6.62 meters, do you mean 2.6 inch pole?
Perhaps it can be square pipe as well? There are many metal shops around here, they have different pipes available, I just not sure wheather it is possible to shop such a heavy items :eek:
thanks square would work ok used it before was trying to find used save money looks like moonbase found solution
Have you checked the diameter of a traffic control bollard, the short height ones? They come in various diameters and one of these might be a suitable diameter?
Value Mild Steel Bollards - 900mm Above Ground · Barriers Direct
The above web site do have 168mm diameter poles but it depends if they are within your budget?
Rgds
thanks that's will do it and cheap enough just measured inner diameter and ok 170mm 168mm will be fine not much room for levelling but doesn't matter I level at bottom of pole
Too many 'Like' posts to do individually but just to say the thread is a good informative read and lots of peeps posting advice etc.
Attached polarmount I made for 3m few weeks ago. Now painted and installed. Base has only 3 long legs..
