ocean04
- 3m 28.5E (53E-8W), 2.4m Aerial AS24 (68.5E-47.5W), Edision OS MIO 4K, Octagon SF8008, Vu+ Zero 4K..
- Western Finland (63N 22E)
Anyone received non-West beams from 42E in UK? There are too many to go through but I did manage to lock 12015H 27500, though picture is stuttering on the F15 and breaking up on Solo2 (no difference in reception between the two). This is on the 4A Turkey beam:
@nelson_b - do you still have the Alcoa pointed at 42e?
No lock on this one @nelson_b - steady 5.7dB, some way off due to DVB-S2/8PSK.
12015H has gone up in strength to 6dB today so no breakups.
Try 12015H again - it's 6.4dB now. 12245H is 6.2dB but no lock...
11096H is nowhere near a lock.. flickering up to around 2dB.
Have you tried to adjust polarisation? Something like very strong 12009V causes problems, if angle is even slighly wrong.Can see a little difference on 12015H maybe reaching 3.db max
... the sky has clouded slightly and i,v lost it again now .... i remember now that using the 1.8 on previous old/east beams - l.n.b skew was critical
... i may also try a different l.n.b. for this frequency ... some perform better than others at certain frequencies .Signal has dropped here... maybe due to clouds.
