Portable satellite dish base
found a used pole to use as king post £30 :) received full go ahead from planning its not needed :)
Wait, let me get this straight...
Do I understand correctly that you (despite feeling the need to make the mobile platform) have applied for a PP to erect a fixed CM2.4 anyway, and got full go-ahead on it??
Did you bribe them?
Does your best mate work at the council or something?
Did you bribe them?
no ive not applied for planning ive made sure its not needed before the install I would advise anyone to do the same before any installation
I know its not needed but planners can make there own rules the case below he was made to remove his tower
Inspector to decide on radio mast appeal
I did not want this happening to me so ive made sure I have in writing planning is not needed
NO ive not bribed anyone and no friends in planning just making sure my dish stays
Then I got you wrong, I was of course writing in a light-hearted mood :)
But nevertheless, amazing feat! Well done!
<thumbs up>
<thumbs up>
thanks i thought best to ask and get the go ahead i will get complaints i have troublesome neighbour, now they have sais yes they will have to support me, if i was to do the install without asking they could bend the rules and make me take it down as in the case above,
more to come on this install i will be able to raise/lower the dish by 3ft to clear obstacle past 57E
Sorry, but , no such thing as pink steel, pink marmol , equates to granite worktop in old English.
Just my opinion !
AND Having read the previous posts, have realised that nobody wants me any more so will post no more on this or any other thread.
Et Tu Brute?
Will be interesting to see how this will be achieved
very easy to do, this will be cut down to approximately 5ft
the king post is a nice fit over the H beam so will sleeve over the top
nuts will be welded to king post at various height bolts will lock king post in place
now for raising/lowering i have in workshop two new winch this way i use pulleys
other option in workshop is farm jack
Farm Jack , High Lift 48
Some time ago, in Texas, this 5m dish was for sale. Price was about 2k$. I was even thinking of getting it, but somehow did not.
I had big dishes in Italy. ok for watching tv not good for hobby. climbing ladders and thousands of pounds playing with lnbs, nice to have though :).
A change of plan, instead of using these as the track
img_2660-jpg.98183
I am now using these
The concreate ones are far to heavy to get where I want them, weather permitting I should get the track down tomorrow, getting close to installation now :)
Track down, need to pick some sleeper screws up get it level, will fill middle with nice stone, make movable planters to go on platform.
