DIY Horizon to Horizon Polar Mount
blademedia
Sky
Hey decided to make this mount
I can easily locate steel work, will use oilite bushes for moving parts Google , need to locate gearbox with anti backlash something like this need to do more research chain and sprocket will use from motor cycle
Two-Way Right Angle Gear Drives | 2-Way Right Angle Gearbox
trying to get a rough idea on size of slewing ring part with chain do you think actuator is 18 inch in picture above
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I do not think this is very easy to make such a mount. Will be interesting to follow this thread. Good luck with the project.
Anonymous_1
a short off topic but related to your project This mount remind me this one I have seen last year while I was visiting a friend in italy..
This si an "Eisat" mount and positioner, very precise, still available on the Italian market but very expensive.
I ve never seen someone else (Dxers) with that stuff, am I wrong ?
blademedia
Sky
don't see any major problems hardest part will be locating correct gearbox, only tool I don't have is ring roller might buy one if not will take steel to fabrication shop for bending
Gear Driven Ring Roller to make metal rings and wheels! Worldwide Shipping!
View attachment 99148 View attachment 99149 View attachment 99150 View attachment 99151
looks a nice mount doesn't look suitable for large dish ?
Looks very similar to the old Fibo H to H motor, but way more substantial, they were a complete headache...
blademedia
Sky
the beauty of making your own I can gear it via gearbox chain and sprocket and make it very accurate might take 4/5 minuets to do the full arc but I want accuracy I will use anti backlash gearbox and good quality actuator motor for build
blademedia
Sky
input shaft connection motor side I can use part from actuator shaft
standard gearbox input shaft
will need to mill end down drill and pin part from actuator
will need to make housing to join actuator motor to gearbox will make from round tube
actuator motor
output shaft cog end to chain
will just weld this
to something like this
Terryl
Custom built PC
cog-png.99161
Cogswell cogs or Spacely sprockets??.............
blademedia
Sky
after a bit of driving around calling at various companies came across a very helpful chap :) need to do some milling/fabrication but now have most parts, little did I know I can get proper clamps to hold cog to shaft will call back to company when I get nearer completion
need to pick more steel up and new cutting blade then can make start on frame
blademedia
Sky
made rough calculation on gearbox ratio of 70/80/1 bought 80/1 just received email from NSC they use 60/1 on new models, Travel Time of 4 Min. 37 Sec. to Cover the 160° Arc, unsure what cog is used never asked but shouldn't be far away slower it goes more accuracy, maybe 6 min 160° can use bigger cog to speed up a little if not happy
Horizon to Horizon Polar Mount Series
chap gave me ruined motor for input shaft, stripped it down nearly perfect fit for actuator adaptor little drilling needed hopefully pick parts up to join motor to gearbox tomorrow
:eek: interesting thanks for the info :)
I doubt the claim of 'the best satellite motor in the world' will last, now the experts here are on the case.
Next, you'll be asked to work on pre-unit motorcycles.
Trust
Nijmegen Netherlands
Search for Rosta tensioner , they have chainwheels with rollerbearing inside .
You will need 2 of them .
