- Oct 21, 2006
- See signature
- North Somerset
How much weight do you have sitting on that arm? Must be quite substantial!
This shows it a little better...
John,
Would you please be able to confirm a couple of settings and wire mapping for me re the APC and the Servo motor?
1st question:
The wiring of the HJ S3315D Servo Motor to the APC looks to be as listed below, can you please confirm?
Servo...................APC
Red Wire.............(RED) +5V
Orange Wire........(WHT) Pulse
Brown Wire.........(BLK) GND
2nd question:
Is the metal flick switch on the APC set to Invert or Normal?
3rd question:
You seem to have some additional labels on the APC that were not present on the units we recently imported. Have you added these yourself?
I have just got my PSU from Maplins and am getting close to the point of flicking switches and powering up.
Rgds
John,
I wired up the servo to the APC as confirmed and tried it out, its working but I am not sure if I am balancing the Invert/Normal switch correctly with the Skew rotation. I marked the Servo wheel that fixes to the Zinwell at the 12 o'clock position and no matter what combination of the Invert/Normal switch and the Skew rotator dial I only get 90 degrees travel anti clockwise and back. Is this adjustable via the small trip pots on the side of the APC?
When I come to setup the AV-COMM barrel with the Zinwell and the Servo I will be using in on linear H and V signals initially. Could you please tell me how I orientate the AV-COMM barrel with respect to the internal steps for linear H and V polarities and the internal probes on the Zinwell? If I can get it setup close to the theoretical orientation then the 90 degree rotation scope I have from the servo might be enough?
Thx
John,
I have not yet attached the servo motor to the Zinwell, I am still testing out the rotational range of the APC/Servo.
My findings so far using a reference mark on the servo wheel are:
1. I need the H ADJ full counter-clockwise and the V ADJ around 2/3 clockwise to get a 90 degree separation when I flick the Invert/Normal switch.
2. I have more than 90 degree rotation with the flick switch in the Invert position.
3. I have less than 90 degree rotation with the invert switch in the Normal position.
4. The over/under 90 degree rotation from 2. and 3. above is about equal.
The rotation is a little bit jerky at times and it twitches about a bit, its not a smooth even rotation all of the time. Generally, the reference mark on the servo end up at the correct location but is sometimes quirky on route to that point. Smooth slow rotation of the Skew button lessens the twitchiness. I might try a different PSU just to see if that smooths things out a bit.
I will see if I can rig up a test dish on an Az-El fixed mount to have a look at it under operational conditions. Could you please confirm that if I align the dish on 0.8W or due south then the barrel side steps are vertical and the Zinwell has the probes at the 10 to 2 position? Is there a satellite that springs to mind that has linear C band polarity with signals capable of being received by a 1.5m dish within 45 degrees East or West of due south?
Thx
I think both Chris (scopus) & me had similar erratic nature when we used a very short piece of cable to test, i tended to use the cable that was going to be used for the run from shack to dish position, which in my case is about 20mtrs, and found that that got rid of the erratic behaviour
Try Paksat 38e or 46e...both linear with some signals available on the 1.5m.
@moonbase 46 E is linear and I can get it with the 1.5 dish and c-band offset by about 3 or 4 °.
Thx Chris,
What are you referring to re the offset of 3 or 4 degrees? Is the C Band LNB not at the central focus of the dish and is offset in a multi LNB arrangement?
Rgds
John,
Thx, very useful tip, yes I was using the short cable that came with the servo. What spec cable did you use for the long run, ie, core diameter, the condictor cores seem quite small diameter, is there a cheap off the shelf cable readily available?
Thx
Years ago I already was thinking about trying to make such AV-COM barrel by myself .
Beginning this year a friend ordered one from AV-COM , from that one I took the dimentions .
A few days ago I ordered the nessasary parts for 2 polarisers , yesterday the package arrived .
The alu tube is 70/60 , thursday I will start with this project .
