DIY Horizon to Horizon Polar Mount
blademedia
Sky
Very nice fabricating skills there, looking very good indeed.
Thanks John,
Connection to dish will be something like this, one picture is from nelsons dish hope you don't mind nelson.
Will keep original dish back joining, will buy/make long ring eyes, will go though dish and join to inside steel,
5mm gap for oilite bush each side.
Eye bolt will be long go through dish and connect to inside frame
blademedia
Sky
Like this idea, simple but effective
Interesting idea!
... Thats a first for me .... never seen that done before
blademedia
Sky
First time I've seen it done like this, like a scissor jack
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Yes, very interesting, great idea. But I would not say simple.
blademedia
Sky
More work done today. its starting to take shape now. gone a bit OTT this is one serious mount. can only just pick the chain part up.
The two vertical parts need cutting to size and welding. then its down to drilling and bearings.
Main concern is the motor its a big heavy duty one but I have some weight here now, Might have to do as trust mentioned industrial motor. don't mind spending 5/6 hundred pound, will see how it goes.
IMG_2893.JPG IMG_2895.JPG IMG_2897.JPG IMG_2900.JPG IMG_2902.JPG IMG_2903.JPG IMG_2905.JPG IMG_2907.JPG
Brunel would be proud of you!
View attachment 99719 View attachment 99720 View attachment 99721 View attachment 99722 View attachment 99723 View attachment 99724 View attachment 99725 View attachment 99726
Like it ....
Can't beat a good sturdy mount though BM (said the actress to the Bishop) ..... you won't have to worry about it coming undone when the wind gets up ;)
blademedia
Sky
Like it ....
Must agree John. but its well OTT. one good thing the chain ring will act as a counter balance and if I ever decided to go bigger it would easily handle something a few sizes up.
Can you actually still lift the assembly? How much more weight is there yet to add?
blademedia
Sky
Yes can lift it but heavy, not much weight to add, maybe same weight as dish.
nelson_b
Contributor
Seriously heavy duty ....:) ... Like it .
blademedia
Sky
Thanks nelson/Chris, will buy some scales tomorrow and weigh it, anything hanging behind pole is 6mm steel rest 4mm its 37 inch long 33 inch wide. motor assemble weighs around 30lb
Edit, Total cost up to now £137
Very nice! What is the finish going to be like? Galvanised or...?
