Phono Stage noise on my amp
pgh13
Midlands UK
Clutching at straws..... is it possible that there's some resistance (possible due to corrosion) between the ground of the input panel and amps main earth point? Your experiments unplugging the left channel and connecting the cable outer to the earth point make me very suspicious.
How much postage to Ireland, bouncing around in several delivery vans? ;)
Do those new fangled drop/collect options go as far as your location ?
Are there any local amenity sites nearby as similar age stuff is most likely thrown away, think analogue dishes.
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
There is a parcel motel nearby and a po box drop off across the border in Northern Ireland that might cut costs
excollier
