French FTA's 5w 9e after april 5 ?
Swing her dish round to 9E :D
Just got around to looking at this and SWMBO still has France 2,3,4 and Overseas on 11591.
Do we know the intended switch-off date?
Edit: Having looked at some of the links posted earlier, it'll be the end of November.
VodzigorLans
Setup is down atm
RU, Saint Petersburg
11137 V Newtec tp is off along with 11589v, so there are two high speed spare tp more, i wonder is something else will be launched there...
Yep.
Dead as some Dodos.
Must shift SWMBO's 5W LNB to 9E.
Adam792
Cheltenham
A possibility is maybe more multistreams, perhaps containing some regional versions of the R1 multiplex (France 2, France 3 etc).
In some areas where the regional version of France 3 is being upgraded to HD, the multiplex is being reconfigured so the two local channels (either two regional France 3 channels or a France 3 and a local channel) are statistically multiplexed with the other channels, instead of the other channels being stat muxed in Paris and fed by satellite (The feed that was on 11591V, now 11509H MIS!) and constant bitrate versions of the local channels being added on site. This allows for better image quality on France 3 as it can go much higher than 5.1Mbps when it needs to, and currently also means that the transmitters no longer use satellite at all for this multiplex as they require a completely unique version. Multistream could enable them to roll this new technology out to some of the more remote transmitters maybe.
Otherwise it could be more pay channels or nothing at all! :D
MCelliotG
Thessaloniki, Greece
The Newtec transponders stopped simply because the whole terrestrial DVB network in France is now being fed by the Multistreams. Newtec is a proprietary system that required loyalties, MIS is much cheaper and easier to setup as the whole multiplex is ready to play in the transmitters with no/minimal modifications.
Most DVB-T/T2 providers transmit the whole multiplex structure as is via satellite. Digea and Abertis do the same, the latter uses Hispasat and each pid (except some regional ones) have a separate mux inside of them which is ready to feed the terrestrial multiplex as is. In my estimation Abertis will pass to multistream as well in the near future.
Pietclock
125cm
SE Germany 50°N/11°E
TF1 HD Suisse and TMC HD are gone at 9 East 12.034V ....
So they have.
Bu**er.
I posted that last night somewhere.....
2night
vantage hd 8000s
120 cm dish
windows 7
friesland (nl)
hoi,
now on eutelsat 33 east in dvbs-2x
12621 v 10058 dvbs-2x
source: king of sat
The fixed beam from Eutelsat 33C @ 33 east :) well inside this footprint
FEC 25/36 :-ohmy
Going to need this one then
TBS6522 Multi-standard Dual Tuner PCI-e Card
Works with these fec's in DVB-S2X
DVB-S2X
QPSK: 13/45, 9/20, 11/20
2_4_2_APSK: 100/180, 104/180
8PSK: 23/36, 25/36, 13/18
8_8_APSK: 90/180, 96/180, 100/180, 18/30, 20/30
16APSK: 26/45, 3/5, 28/45, 23/36, 25/36, 13/18, 140/180, 154/180
4_12_16rb_APSK: 2/3
4_8_4_16_APSK: 128/180, 132/180, 140/180
I wonder if the commercial satellite industry will ever catch up with these formats that have been around for a while now :-doh
They probably won't bother so TBS is the only way for enthusiasts :)
blademedia
Sky
DVB-S2X
4_12_16rb_APSK: 2/3
@Llew :)
dx qwer
www.satellitescommunity.de
C-Band: ORBITRON O-16 (4,9m)
Rastatt/Germany
Got it too.
Thanks guys, at least it's getting the card to work a little more for its living :)
Lucky barstewards. We, OTOH, are now a frog-free zone.
blademedia
Sky
Bought a new tv today S2x working fine
Adam792
Cheltenham
I take it these LG TVs are Freesat approved too?
Was just thinking that 33°E is a nice easy offset from 28.2°E for a couple of bonus French channels, presuming the signals are nice and strong? (I think I saw a footprint map the other day showing it as 54dBW over a big chunk of the UK).
Sent from my iPhone using Tapatalk
Pierangelo
150 cm from 80 east to 40 west + C lnb
Italy
Great, which tv?
thanks
