epg audio channel
John Pykett
Persona non grata
Dish setup: 80cm Motorized Dish, TM-5402 HD M3. This setup goes from 1w to 28.2e
My computer setup: AMD Athlon II X4 645 3.10 GHz processor and 8GB of ram. Graphics Card is NVIDIA GTX 750 Ti. OS: Windows 10 64 Bit
Hucknall, United Kingdom
hey, im wondering if it is possible to get the epg audio channel on freesat boxes instead of sky boxes
IIRC its flagged as a data stream rather than a radio stream & many receivers ignore data streams.
Yeah - and if your receiver ignores data streams you aint going to find it! It doesnt show up on my Technomate.
ill check whats the frequency?
Just as a matte rof interest WHY do you want the Sky epg audio on a Freesat box??
it seems you were right my box dont pick up anything from that frequency
Hi .. Just had a look here out of interest ... using DrHD F15 receiver ...
working ok with this box ...
edit ....
Also ok on Technomate 5302 HD
Just put a Pink Floyd album on in the background.
what the... how did you get the sky epg audio on intelsat 702?
They're just editable labels ... only of real meaning if properly correlated with where the dish is pointing.
We often use previously redundant or unused "Satellites" for messing about. Means you can check out transient points of interest without laboriously going the whole hog and giving everything its right name.
hmm okay
Oops ... ignore the satellite position listing i "was" pointing at 28 east on both tests
It seems you are unlucky with your receiver ... i,v just tried also with the Cheap and cheerfull
Openbox/ M3 Skybox and the epg audio music is working fine on that one too ....
Regards ...
Regards ...
The proprietary Freesat boxes, which I believe OP has, don't recognise Data flags - apart from the Freesat Default TP, obvs.!
A case of generic functionality being suppressed for the average plug-and-play punter's "benefit".
Not as crippled as Sky boxes, though but!
also i have a old sky+ box lying around i dont know what to do with it :wacko:
Welcome to the club!
I suspect most of us have got old Sky boxes and several proper Satellite receivers stashed away in our man caves, as well as old dishes, brackets, motors, LNBs, bits of electric string and heaven knows what else :D
