@ st1
At the beginning, I ask you to come to sack in the post.
In the photo with the measurements you indicate and other photos, you have it with the antenna cable at 6 (imaginary relog), it would have to be almost at 8 (28.5E), At 7 is for 19'2ºE +/-.
I'm referring to the adjustment of lnb polarization, it's wrong, looking at the antenna in front.
Do not forget..
What size of antenna do the neighbors have in Nordsjælland, Denmark?
@st1
De entrada te pido perdor por entrar a saco en el post.
En la foto con las medidas que indicas y otras fotos, lo tienes con el cable de antena a las 6 (relog imaginario), tendria que estar casi a las 8 (28.5E), a las 7 es para 19'2ºE +/-.
Me refiero al adjustment of lnb polarization, esta mal, mirando la antena de frente.
No olvides..
¿Qué tamaño de antena tienen los vecinos en Nordsjælland, Dinamarca?
Thanks for the pictures/Gracias por las fotos.
Of course, the LNB brackets are not from this OP130 antenna.
Tomorrow, if time permits, change them.
The new stand is the same as the one you have ST1 95cm, Jhon has the same, with the new LNB support and the carton of the disk
100% plan.
Photo so you can see the difference, the LNB is 2cm higher, than cold, freezing the fog.
Esta claro, los soportes/tirantes del LNB no son de esta antena OP130.
Mañana si el tiempo lo permite, los cambio.
El nuevo soporte es igual al que tienes ST1 95cm, Jhon tiene el mismo, con el nuevo soporte LNB y la caja de carton del disco
Plano 100%.
Foto para que se vea la diferencia, el LNB queda 2cm mas alto, que frio, congelandose la niebla.
@ Trust1
It touches change orientation (Astra to 19'2ºE currently) and also elevation by the new position of the LNB.
The photo tricks the angle, points higher the LNB.
The support of the plate has no elevation reference, I have marked the position for 19'2°East and 28'2°East.
I will have to look tomorrow, I think if you have screen printing elvacion, total memory failure.
Toca cambiar orientacion (Astra a 19'2ºE actualmente) y tambien elevacion por la nueva posicion del LNB.
La foto engaña por el angulo, apunta mas alto el LNB.
El soporte del plato no tiene referencia de elevacion, tengo marcada la posicion para 19'2ºEste y 28'2ºEste.
Tendre que mirar mañana, pienso que si tiene serigrafia de elvacion, fallo total de memoria.
