- Oct 21, 2006
- See signature
- North Somerset
It was surprisingly light, thought there was just paper inside the packaging!
<far-fetched>Unbelievable what is going on! If I remove the foil the signal is lost immediately! Can somebody explain what that could be?!
Yes, I know, but that can happen only during sun-outage periods. Next period is early spring next year.... I doubt this antenna will stay so long And, secondly..... I have more than 10 LNBs, I do not mind to burn couple of them.you cant really put a reflected surface on it, it will melt the lnb on a warm day
Then it should work with Ka-band as well. ;)Maybe it's a nano-BUD?
Rimants , dont you have such detector for cable or pipes in the wall ?I was almost desperate and started to suspect that this is some kind of Toy-antenna, made for fun or exposition purpose, it even can no reflective layer inside .
Abyway, my next step will probably be to find the place where they apply layer of metallic (reflective) cover to the surface.
I just love this antenna, it gave me so much fun and seems that is is unique.
Should be easy - detach from mount, and hold in front of radio path to existing similarly-sized dish to "block the view".Wim! I know what are you talking about. No, I do not have it, but will try to find and check whether Tiny has some metal inside.
Yes, but that is great! It has perfect shape and produced by well known company. And, most importantly, there are not so many same dishes (if any) around.So it's literally a toy dish?!
