Are you competing with Southern Rail?
Hello Lazarus, i couldn't think what else to work with tbh, i wouldn't like to try and compete with them, i wont have much change from £1000 doing a 4,8 mtr run including base Something like this will be placed on sleepers to stop system sinking into wood, drill thread and weld nut to plate
Good stuff ......
When you have got the rail system up and you have had your fussy out of it, i want you to think about a modification to it for next year when the sun comes out again and think about digging a large pit in the lawn in the same place as the track wood and make the whole dish assembly lower down into the pit on something like a second hand car lift from a garage sale or summat. Then, to keep the better half happy, construct some fibre glass "rockery" panels to drag over the pit when the dish is not in use. We expect to see a new thread about this around April time ... piece of cake Blade.... do it.
I am already working on something but not to that extreme atm All this talk of hiding the dishGood stuff ......
All this talk of hiding the dishThunderbirds come to mind
tracy island! prehaps you could hide the dish under a sliding garden pond
TBH I didn't realise I was trying to hide it, but I guess I am in a way, I am trying to make it blend in, guess that's hiding it,
Now ive retired I like spending time in the garden gives me something to do, though I think the channel master 2.4 is a work of art, I would be sooner looking at something like this,
If I don't do the bits I am doing will regret it do it once and right
You may need to tip the whole thing 0.000002 degrees to the East, that should level things down a bit.Sounds like I need modify the levelling system![]()
Picked more martials up for this today, mainly for levelling system, decided to make the whole platform to be levelled, made one they will bolt on with the wheels at six points
