Yamal 402 at 54.9E
chucklebezza
39east and 19e when I want to see F1, using a tm1500ci
surrey
Anyone know what is the smallest dish required to get the EPL footy on MatchTV? I've got a 1 metre
motorised system and Ive just seen a 1.15 Metre dish, which I may get.
Cheers
I struggled to receive that with a 90cm Fibo dish in Somerset - a good 1.2m Channel Master (available on your favourite auction site) should be enough in Surrey.
Ive only ever had the merest sniff of the northern beam here with a 1.1m dish even in absolutely perfect atmospheric conditions. I gave up on 55E when the Euro beam was switched off. In Surrey a 1.5m might give you a chance although Id say you wouldnt have much rain fade
chucklebezza said:
Anyone know what is the smallest dish required to get the EPL footy on MatchTV? I've got a 1 metre motorised system and Ive just seen a 1.15 Metre dish, which I may get.
Of course what I'm picking up in my area,Romania,is not true for other location,including Surrey.But I think there are enough enthusiasts who want to find out about what they can be received on Yamal-402 in their area relative in my area with 150cm dish and lnb IBU.Here is a list of transponders which I found with EBS.Who knows,it may help...
blademedia
Sky
I get it occasionally with 1.2 dish, maybe 1.8 dish needed here for 24/7 reception
chucklebezza
surrey
Thank you all for your help, by the sound of it the 1.15 mtr dish I was contemplating would not be big enough.
blademedia
Sky
Have a try for 12531 H 2500 radio channels strong signal here, also 12522 V 27500 thats about all i get, 12716 match tv comes and goes,
12522 TB 41
blademedia
Sky
Just noticed okhota i Rybelka is FTA atm :)
pontiend
Contibruter
south yorkshire
I have been fiddling with the settings for this satellte most of the afternoon.
First off, I was getting a lot of verticals from 57 East.I eliminated those from my scan ranges.
Next because it is a fringe satellite for me finding the best Longtitude setting was next.My longtitue should be 1.5 West.Using 0.1degree incriments between 1.1 and 1.5West 1.3 seems to be the best that I can do. 0.1 degree either way I loose DB or even some transponders.
So this is the best that I can do just now.
Sorry about going on a bit once I get going it takes some stopping.A bit like going to the Loo really. :)
TBS6983 100cm Dish.
Never mind getting Match TV from this satellite, 4 transponders were switched off today. :(
12673 V (T2-MI), 12693 V (T2-MI), 12715 V (Match TV & Rossiya) and 12729 V (5 others).
MCelliotG
Thessaloniki, Greece
So this is why I was scratching my head with these today! lol
Too bad since I only managed to semi-fix my orbital arc on my system this Tuesday, so I nearly had a chance to see these T2-Mi in action!
Anyway, I receive all the active Northern and Russian frequencies, some very marginally (I'll make a detailed report in the coming days).
12715V was very marginal @ 7.2db and 12693V was at 8.3db stable, I couldn't receive 12673, I think it was stopped before the switch off. 12729V used to be stronger, but was very marginal as well at 7db.
shawl_who
SES7, Yahsat 1A, Yamal 54.9e, express am33 @103e, eutelsat 36b
New Delhi, India
Wish they start more channels on the russian beam, as I m getting 11265v tp from russian beam in delhi. ;)
I wish that too, 11265 V is reliable here, 6...6.5 dB !
Can someone who has strong signals please check 12680 H, it is 7.0 dB here without lock.
I think it's new, not in satesco's scan above.
Edit: never mind, found on Lyngsat, will be a Gazprom data transponder (symb. 30000).
shawl_who
New Delhi, India
I am unable to get a lock on 11345v tp, also on the russian beam. :confused
May be bcoz 11265 is dvb-s
11345 is dvbs2
CERIN
16,0 Е - 140,0 Е
Супрал 0,9м. , TBS-6925 (PCI-E DVB-S2 Tuner Card)
Russia
shawl_who
New Delhi, India
Acc to this, 11345 has 17.2 dbW beam power and 11265 has 15.9 dbw.
Still unable to get 11345v.
CERIN
16,0 Е - 140,0 Е
Russia
hvdh. 12682H 30000
shawl_who
New Delhi, India
12680 H
Cant seem to find a TP with those parameters.
There a tp 12685H 30000, but ts 16APSK
