Astra 2E at 28.2E: General Discussion Part 1
Pride Of Cucamonga
Valencia (city)
Yep - since the end of November we suspect!! I think we may now see some testing at the weekend, will be interesting to see if any of the 33MHz TP's are tested on the UK beam?
Why are the higher frequency transponders wider bandwidth, a legacy from the analogue days?
Pietclock
125cm
SE Germany 50°N/11°E
I've done a scan of the 33MHz transponders for comparison to 2E when it goes live. There are two very weak strange carriers on 12137V and 12432V.
Pietclock
125cm
i got signal but no lock it
They are in ACM mode, different modulations, mostly APSK16.... you need an APSK compatible tuner for them
it signal before switch tranponder both satellite
A constant carrier on 10942H.
No. The needed bandwidth is related to symbol rate. Normally it is 35-40% more than the symbol rate.
Retired Mod
www.timo.me.uk
@solly: the two data carriers on 11,464H and 11,479V have been there for months now. Both 16,5 dB SNR here - they most likely are on the 1N PE beam.
Those aren't 1N PE1 but could be 1N PE2 as they are strong (17dB ) on my 80cm dish in Finland whereas I can't even see a blip from the 1N PE1 transponders on a 1.8m dish.
Schroeder
2.2m Pasat prime focus with Invacom c120 quad LNB, PACE DS430N, Ferguson Ariva 200, Humax Foxsat HDR
Albatera, Alicante, Spain
Is it possible to see a carrier on a digital sat receiver?
Schroeder
I guess it's probably the lowest frequency they can use to check the UK spot beam without causing any interference to live transponders.
kevjs
28.2/5'E Zone 1 Mini Dish connected to DVB-S Tuner into TVHeadend/XBMC with a 60cm dish bought out for Astra 1 on Grand Prix weekends. With Android XBMC box in the kitchen too.
South Notts.
With Astra it is a legacy of the analogue band plan isn't it?
i.e. the analogue broadcasts on Astra 1A to 1D had 26MHz of Bandwidth needing 16 transponders for 250MHz.
Along comes Astra 1E/1F and they decided to use 20 transponders to cover 400MHz spectrum so these are 33MHz wide (if these had been used for analogue TV it would have been rather wasteful).
Then as Sky turns off it's analogue transmissions digital services start in the old analogue bands, but squeezed between the analogue channels and on the same craft so forcing a slightly less efficient use on those bands. With the G band being the same size as the analogue bands it looks like they kept the 26MHz bandwidth there too.
For whatever reason SES Astra like consistency (i.e. the same transponders in use at three different orbital positions - 19,2'E; 23,5'E and 28,2'E) so while 28,2'E wasn't used for analogue television it's ended up following the same plan as 19,2'E.
Pietclock
125cm
The 26 / 33 MHz thing has nothing to do with analogue or digital. All analogue Astra channels were on 26MHz transponders, which was a SES "specialty" in the beginning - they used that as a compromise between quantity and quality, because a 26MHz wide analogue FM carrier was not of the same quality as a full 5MHz PAL carrier, which was the analogue terrestrial standard. For real studio quality, 36MHz transponders were necessary.
When SES launched their digital service in 1996, they again did some compromise using those 33MHz instead of 36MHz on Astra 1E and Band E...
I get anything on 10942H here.
@timo_w2s: yes I agree, they are 1N PE2, while those data carriers in Band C are 1N PE1...
Pietclock
125cm
The reason is interchangeability. So they can move the satellites around as a back up when needed and as they have done several times.
Retired Mod
www.timo.me.uk
And this is the main reason for European beams too. A satellite full of small UK spot beams would not be useful at other orbital positions that need to cover larger areas of Europe.
Expats and conspiracy theorists may disagree though...
Acuario
Tortosa, Catalunya
www.tortosaforum.com
1.2M Gibertini, 1.9 Famaval, 0.2dB Invacom LNB, Iris 9600HD, TBS5922
Southern Catalunya
Here are scans taken in Tortosa for future comparison.
For interest would someone who has good reception of 2F on a 1.2M dish or less post a scan; I would like to compare it with the scan here.
On a 1.2M dish there is absolutely nothing, on a 1.9M Famaval there is (sorry it's 2F not 2E related).
joddle
Massanassa, Valencia, Spain
Should I be able to see anything for 10942H here on my Foxsat? - so far no signal or anything!
Afraid not. The carrier is still active at present on that frequency, as previously shown in my screenshot, but it's a very narrow unmodulated carrier, and cannot be seen other than with a fast-sweeping spectrum analyser.
Tururu
Assembled with recycled parts
Recycled as the owner.
From Madrid (Spain), 94cm motorized antenna. (1-2-2014 2:00)
Desde Madrid (España), antena de 94cm motorizada.
ettore88
Gibertini 105cm 45E-42E-39E-36E,Gibertini 105cm 33E/31,5E-28,2E-26E/25.5E-23.5E,Gibertini 105cm 19,2E-16E-13E-10E/9E-7E-5E,Gibertini 105cm 15W-12,5W/11W-8W/7W-5W/4W-1W.Decoders:CT HD 5100C/CT2100+
Notebook HP Windows 7 Ultimate
Italy
Greetings to all ! I ask you that you are aware : the passage of the channels BBC / ITV will be the new frequencies , or stay the same ? The Big day will be on February 8 ? Thank you in advance !
Inviato dal mio GT-I9100 utilizzando Tapatalk
