Astra 2F at 28.2E: General Discussion
cazhh
Elmshorn, Schleswig-Holstein
"How much for the Gnome"?
cazhh
So, any idea why SES continues to move the beam ?
We've had two big jumps, one end of october and now again. Both times the average maximum increased by about 2db here. That is a shift of in total about 40km to the east. Combined with the smaller increase beginning of september we are talking of a shift of about 50km since the summer. That is a lot.
On top, the difference between good and bad days until september was huge, sometimes more than 4 db. Now it all seems to be much more stable/controlled.
M60
Northern England
How is reception around Valencia anyone as this was in a hotspot? I wonder if they are trying to move the hotspots over sea to prevent overspill in areas such as this?
Pride Of Cucamonga
Valencia (city)
Ha, great conspiracy theory - but that would give the Balearic Islands a better signal. . Can;t say I've noticed any difference.
May not be an alignment change. Could be LNB distance has changed... or minor damage to the reflector surface, by a grain of dust or similar. Anything that causes the slightest defocusing of the beam is sure to improve things on the fringe.
joddle
Massanassa, Valencia, Spain
Not noticed anything different at all recently but then my dish is a bit of an overkill at the moment so perhaps I would not notice anything anyway. All 2F channels seem to be fine.
M60
Northern England
Thought it was worth checking as could be something they've done in this respect. Maybe, as Huevos says, it's down to something external in terms of dust or tiny particles. It seems to have worsened reception in Tenerife and the Canaries by the sounds of things.
mar-val
Slovakia,Zilina
No or very bad reception here,till now. Last days I can lock few TPs,even new 8PSK.
Best signal is around noon.
Waveguide
Dish and box
North
Maybe somone in Iceland said -
Gerðu svo vel, opnast skyndilega allur eldfjöllin!
(Please - quickly turn on the volcanoes)
... or have you forgotten what happend last time they did?
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
it can be also good weather in UK, for "uplink".
and also cold winter weather in Europe..
S
Steve Steve
2F uk ..still very high here....ch5 receivable on the 100cm dish ,last night....,!....at the mo 150dish 100Q....100cm dish 70Q.......
bema
Kungsbacka
www.sm6muy.se
TV server: Linux Ubuntu 14.04 LTS
TvHeadend 4.1-1355
TBS6904 (Quad DVB-S/S2)
Dish: TD110, Inverto black ultra quattro
TBS6205 (Quad DVB-T/T2)
Ant: UHF 100 El Triax, dir N
Client: Kodi v14.2 etc
Sweden
The UK spot beam for 2F is definitely turning back and forth. I have measured the SNR since March last year. I can't compare the result exactly from that time since we had a couple of storms during the autumn so I had to re-adjust my dish several times. But to see daily variations it’s easy. The tendency over this time (since March last year) is definitely that the beam shifted slightly more to the east, at least at my latitude (higher daily variations). This can probably only be noticed by those who live close the nulls....
cazhh
It's not the weather and it's no dust.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
here in Tallinn is no difference..
only, in night with -15 C ,no clouds, I get 12207V 1N with 5dB and picture (125x140cm+tbs5922).It never happened before.
S
Steve Steve
Could 2F have been moved position slightly ...so the UK beam has also moved a bit ?... ....with the arrival of 2E soon...maybe a Parking space is needed...?........tell me to shut up ...if you like ......with my silly ideas .... :-)
M60
Northern England
Could 2F have been moved position slightly ...so the UK beam has also moved a bit ?... ....with the arrival of 2E soon...maybe a Parking space is needed...?........tell me to shut up ...if you like ......with my silly ideas .... :)
Every suggestion throws new ideas in to the pot and all good. I can't see a shift of such a tiny amount making a difference on ground level to the extent people are reporting?
cazhh
no parking space. There is enough space.
I've been monitoring this thing now for more than a year. There is NO correlation between the satellites position inside the box and the SNR variances.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
No, still OK here - no noticeable change.
Edit: no noticeable change from 2f. Some 1n signals are better than previous recordings (quality/strength) taken at this time of year.
